Results 1 to 5 of 5
Thread: oscillating spindle sander sleeve trick
    Fort Washington, PA
    180
    I often have a tough time getting the sanding sleeves on the oscillating spindle sander spindles. Either the sanding sleeve is a bit small, which is probably the case, or maybe my spindle is just a tad too big. (it's a Grizzley G1071). In either case, this is one of those "it may as well be a mile" deals because even a little tight and those suckers just won't slide onto the spindle. You can only beat on them so much or they will deform or break apart. I tried silicon with some success, and then even better success using talcum powder. Couple of times ended up cutting the sleeve in half as that's all I could push onto the spindle. Since most of what I sand is less than 2 inches thick, that was not a problem. Still it was difficult though to get the sleeve on. Finally hit on something that worked well... a tailpipe expander. Auto parts stores sell them, but some are pretty pricey. Found this in a HF store, was cheap, but since I'm not cranking down on a metal tailpipe it's overkill and it works great. Insert the thing into the end of the sleeve and crank it open till the sleeve is stretched open a bit, then sprinkle the inside of the sleeve and spindle with talcum power and it slides in much easier. HF sells 4 or 5 different size expanders down to 1 inch I think, this one is for the 2 inch sleeve, which is the one I use the most.
    Build it Break it Fix it ...repeat
    The Heart of Dixie
    4,268
    Got to finish my restoration on my OSS. Which just means buying the spindles and wiring it up. But that sounds like a great idea.
    Custom built boats and Kits
    try placing the rubber in the freezer for a bit....
    Fort Washington, PA
    180
    Thanks Tod, good idea, I'm going to try that next time before I do anything with the tailpipe expander.
    13,448
    Great tips guys, Haven't worn out a drum yet, but will keep them in mind when I get around to it.
  1. State B4 Oscillating Spindle Sander Acquisition
    By Matt Hutchinson in forum General Woodworking Q&A
    Last Post: 12-16-2015, 10:30 PM
  2. Replies: 9
    Last Post: 03-31-2014, 01:41 PM
  3. Shop built Oscillating spindle sander
    Last Post: 05-06-2013, 02:12 AM
  4. Powermatic 14 Oscillating Spindle Sander...
    By Greg Cook in forum New Tools
    Last Post: 04-05-2008, 05:35 AM
  5. Merry Christmas to me! ...new oscillating sander
    By scott spencer in forum New Tools
    Last Post: 01-28-2008, 04:32 AM
