Results 1 to 8 of 8
Thread: File type
    Floydada, Tx
    1,941
    File type
    I was trying to open a file and it would not open. So, I downloaded word veiwer from microsoft. When I try reading it shows up as boxes and symbols. Any idea on what to do? I a not real good with pc software.
    Sep 2007
    Plainwell, Michigan
    4,857
    Al,
    What is the title of the file, especally the ending, for example ".eps, .ai, .jpg"?
    or something in that order?
    Tom
    Give us the filename Al. The part of the name following the dot will determine what application you need to view it. .doc = MSWord, .pdf = Acrobat or Reader from Adobe, .cdr = CorelDraw, etc.
    Floydada, Tx
    1,941
    It is a .docx file. If intrested, I can send it to someone.
    Well, the .docx file should be a Word 2007 file, so the latest version of the Microsoft Word viewer should have worked. (There's a possibility the file is corrupt, so no reader would be able to open it.)
    I have no experience with this site, but you might try here:
    http://docx-converter.com/
    Sep 2007
    Plainwell, Michigan
    4,857
    Vaughns right on.
    Microsoft Open Office XML Format (.docx). This format is not compatible with older versions of Microsoft Word or with alternative operating systems like Linux or Mac OS X. Nor is it compatible with other word processing applications like OpenOffice, Lotus 123, or NeoOffice.
    check out his link, should be of help.
    Tom
    Suburban DC (formerly western PA)
    176
    Hi Al,
    If you are still having problems after visiting the converter site, I would be happy to take a look at it for you.
    --MJ
    "We didn't lose the game; we just ran out of time."--Vince Lombardi
    WNY, Buffalo Area
    873
    Like was said before, a new version of MS Word or the Word viewer should open it.
    There is a possibility that you are getting goofy symbols because your computer does not have the original font that it was written in. Try this, in word, select all of the "text", then change it to a common font, like Arial or Times New Roman. It might work like that.
    Or, as already mentioned, the file might be corrupted.
    www.tinyurl.com/thewoodshoppe
  1. New File Uploader
    Last Post: 02-15-2014, 04:05 PM
  2. A Spoke File
    By Stuart Ablett in forum Flatwork Project Showcase
    Last Post: 09-13-2012, 01:03 PM
  3. How I file a Rip saw
    By Victor Skellett in forum Neander Tool Questions and Show & Tell
    Last Post: 08-21-2010, 11:00 PM
  4. Quick File Handles
    Last Post: 11-20-2009, 11:03 PM
  5. Large PDF file
    By Aaron Beaver in forum Off Topic Discussion
    Last Post: 12-04-2008, 07:23 PM
