Results 1 to 10 of 13
Thread: Questions
    Nov 2007
    Nashville, Ar.
    53
    Questions
    Hi everyone,
    I have a couple of questions, 1- could someone tell me what DNA means and #2 is, I have seen somewhere on one of the forms a list of terms used on our forms, but can't find it, could someone help me locate it. Thanks, Jack
    Rio Rancho, NM
    1,417
    Jack,
    Here's the list of acronyms - http://www.familywoodworking.org/for...ad.php?p=68849 - and DNA is denatured alcohol, which a lot of turners use to help dry their rough turnings.
    Nancy
    Nancy Laird
    dandnspecialties@msn.com
    DNA = denatured alcohol
    Usually used by turners to soak bowls in to dry the wood before finish turning them.
    Nov 2007
    Nashville, Ar.
    53
    Thanks Nancy and Robert
    I appreceate your answers and my next question is two foil, is this the same stuff you buy in the local drug store and do you mix it or use it straight?? Thanks Jack
    Goodland, Kansas
    4,834
    Jack you can get denatured alcohol at the local hardware or lumber yard in the paint section. The stuff you get at most drug stores is not Denatured and IIRC is only 30% alcohol. Denatured is straight alcohol with a additive added to make it undrinkable.
    Bernie W.
    Drums, PA
    292
    DNA is Ethanol with additives to make it undrinkable.
    Most DNA that is sold at a Big Box store is between 90%-95% alcohol
    If you know somebody with a still that will sell you "White Lighting"...
    S E Washington State
    3,777
    Quote Originally Posted by Bernie Weishapl View Post
    Undrinkable? Hick!
    Ok, I was going to try and answer the #2 question about #2, but I'm not well versed enough to express my feable thoughts. I found this site you might look at. Explains it pretty well.
    http://www.beautifuliron.com/mttaper.htm
    Nov 2007
    Nashville, Ar.
    53
    Quote Originally Posted by Paul Douglass View Post
    Undrinkable? Hick!
    Thanks everyone, but so far no one has explained how to use it, for how long, and if you mix it or not.
    Paul, I thank you for the link, but it lead me to a site about Beautiful Iron . Thanks Jack
    Oct 2007
    Harvey, Michigan
    687
    Jack - the following links should provide you with all the info about the DNA process that you will ever want or need. If you have any questions after checking the links out - let us know and we'll all figure something out!
    http://alcoholsoaking.blogspot.com/
    http://alcoholsoaking.blogspot.com/2...ercentage.html
    http://www.woodcentral.com/cgi-bin/r...cles_473.shtml
    Steve
    29,315
    Quote Originally Posted by Jack Tanner View Post
    Thanks everyone, but so far no one has explained how to use it, for how long, and if you mix it or not...
    In a nutshell, it's typically used straight (not diluted or mixed). A rough-turned green wood piece is submerged in a bucket or pan of DNA for anywhere from 18 hours to a few days. Most folks soak for about 24 hours, but going longer is not a problem. After the piece has soaked, it is removed from the DNA bath and wrapped in a few layers of paper, A lot of folks use newspaper or brown paper bags. This helps prevent the wood from drying too fast, but still allows it to breathe. Everybody has their favorite way to wrap the soaked piece...some wrap just the outside of the bowl and leave the inside exposed to the air, others don't wrap at all and instead place the piece is a paper bag (sometimes with more wood shavings in the bag as well). I think some people have a special dance they do while waving a string of chicken bones and chanting ancient Inca woodworking prayers. Me, I wrap the whole thing pretty loosely in about 4 or 5 layers of newspaper, sometimes leaving some of the inside of a bowl unwrapped. It seems to work, so I keep doing it that way.
    The end result of all this extra effort is that the rough-turned piece dries faster than if it had been left to dry naturally. Typically, the DNA-soaked piece will dry in 3 to 4 weeks, whereas if it was not soaked, it might take up to 6 months to dry. It is also theorized that cracking and warpage are minimized by soaking in DNA, but I don't know of a good way to prove that.
    Dave Smith has done a lot of studying DNA soaking. Here's an article on WoodCentral for more info:
  1. More CNC questions
    By Carol Reed in forum New Systems and Builds
    Last Post: 01-31-2016, 06:52 AM
  2. 2 questions.
    Last Post: 12-29-2012, 11:02 AM
  3. DC questions again
    By Carol Reed in forum General Woodworking Q&A
    Last Post: 12-24-2010, 03:13 PM
  4. First Pen and some questions
    By Sandy Masquith in forum General Woodturning Q&A
    Last Post: 03-05-2008, 05:12 PM
  5. 6 PVC questions
    By Wes Billups in forum New Tools
    Last Post: 06-05-2007, 10:31 AM
