Results 1 to 10 of 26
Thread: Granberg G555B Mini Mill
    Fredericksburg, VA
    161
    Does anybody have any experience using this small chainsaw mill? I've started giving some serious thought to picking up a light-duty, hobbiest-type chainsaw mill to start using at my in-laws place in the Pocono Mountains. I know that there are size limitations with this type of mill, but I'm not too worried about that for right now. The reviews I've read seem to indicate that this is a decent little piece of equipment, but I'm looking for more feedback. Also, any thoughts on like-type equipment would be appreciated!
    "Listen, here's the thing. If you can't spot the sucker in the first half hour at the table, then you ARE the sucker. "
    Topeka KS
    118
    looks like something a person could build themselves. like a straight cutting edge for a chain saw
    Als ik kan
    11,833
    Chainsaws, for the most part, are not designed to cut along the grain. I have tried with dismal results. I have heard that chains can be specially ground to handle this chore. Or, maybe, special chains can be purchased. Without those, I'm sure you will not be happy with the mini-mill concept.
    Cedar Park, TX
    320
    Yep, they do make special "rip" chains for chain saws. Not something you are likely to find at the big box stores though.
    Chains saws waste a bunch of wood because of the humongous kerf. I think that for most stuff you could handle well with one of those type contraptions, you could do better on a band saw with less waste and a whole lot less hazard.
    Jerry
    Don't waste your money...
    My father had this very idea as well, then looked online and finally purchased plans for a chainsaw mill.
    Even with a big saw...
    Even with a store bought ripping chain (you can make your own very easily though....
    Even with a big bar and small logs....
    We ended up cutting one board today, and got the next board the next day. That is a long way of saying the thing was slow. VERY SLOW!
    We fabricated the sawmill ourselves saving us a pile of money, but even going right by the plans, the saw just did not pan out. The saw kerf alone was terrible, and this is from a family that has a 1/4 inch rotary sawmill, so we know what sawdust waste is.
    lose one out of 4 boards to sawdust on a rotary mill
    lose one out of 3 boards on the chainsaw mill
    lose one out of 16 boards on a bandsaw mill
    In the end we ended up scraping the chainsaw mill. I even think I have a picture of it. My honest to goodness opinion...don't waste your money. save up and buy a smaller bandsaw mill.You will be better off in the long run.
    810
    My humble opinion;
    Like many tools, a chainsaw mill will have limitations and will require that the user learn how to use it so as to lessen as far as possible those limitations. My experience with chainsaws and saw chains tell me that just about everything posted so far is true.....
    but ....
    If your goal is to produce a cant (beam / block of wood) that you can haul home to put on a bandsaw to resaw into usable boards, and if the logs you are sawing into cants are big enough that you can't handle them easily as logs, then I think a chainsaw mill is a good way to get from logs to lumber with minimal expense.
    I own a band sawmill that will handle a 30" dia. log, and I am currently running into logs that I will need to make smaller so that they'll fit on my mill. My choices are to truck the logs to a circle mill to be cut into cants, or to set up a chainsaw mill and make them smaller myself. I'll be doing the chainsaw mill.
    Don't listen to these guys,
    I built one and cut a TON of wood with my chainsaw mill, it worked well, yeah it was hard work, but once I got my chain reground to a rip chain, and had it sharp, pushing downhill the saw just about pulled itself through the log.
    Don't believe it, look at this..........
    >> Logging in Tokyo << (about 4 pages worth there, that is just the first page)
    That is a 4 hour or so day, I would start around 8 AM and have to knock off when the other crew took their lunch break, around noon. A little more than one board a day
    Here is how I built the mill........
    >> Tokyo Log Hog <<
    You are not doing this for money, to make a living etc, so I don't see why you should not do it, get a mill and have at it. An older saw is better, IMHO, as you can find a good one cheaper, and if it has the longer stroke motor, it has more torque, and will work better in this situation.
    I know others will say I'm wrong etc, but I did not just talk about it, I did this, I have a bunch of VERY good pieces of lumber now, that are just about ready to use (air dried) and I'd do this all again.
    Sure the kerf is wider on a chainsaw, compared to a bandmill, but it is all too common in bandmills for the boards to come out a bit wavy, and even just a bit, like a 1/4" on an 8' long board is just as much waste as a chainsaw kerf, so I really think that is a false argument, others will not, that is fine, I'm just offering up my point of view.
    Good luck!
    Fredericksburg, VA
    161
    Stu, I remember the saga very well!! You lost quite a bit of sleep that week, if I remember correctly?
    I appreciate everybody's input!!
    - Keith
    Topeka KS
    118
    see i told you some one could make it! leave it to stu to be the one
    Als ik kan
    Those boards look big, but keep in mind they are leaning against a van the size of a shopping cart.
    To see the Tokyo Log Hog in action, tune in here:
    http://youtube.com/watch?v=mpHWs87laqo
  1. Alaskan Small Log Milling Attachment by Granberg
    Last Post: 07-31-2014, 08:21 PM
  2. The new little mini pepper mill kits from PSI
    By Chuck Ellis in forum Lathe Project Showcase
    Last Post: 07-13-2012, 12:41 AM
  3. Saw Mill Prices to Mill Lumber?
    By Mark Rice in forum General Woodworking Q&A
    Last Post: 04-10-2011, 08:43 PM
  4. First Pepper Mill and Salt Mill
    By Pete Jordan in forum Lathe Project Showcase
    Last Post: 07-13-2008, 04:50 AM
  5. WoodRat Mini-Mini Review
    By Frank Pellow in forum New Tools
    Last Post: 11-23-2006, 06:41 PM
