Results 1 to 10 of 14
Thread: Working with Acrylic
    I want to make patterns out of acrylic that I can buy at home centers. I can cut the shapes fairly well with my bandsaw (24 tpi blade), but are there router bits that would do a better job? Don't suggest MDF etc, these are for my wife who quilts.
    DKT
    My first thought is that a router is too fast and would melt the acrylic.
    Suburban DC (formerly western PA)
    176
    Hi Dietrich,
    A long time quilter and friend recommends a tool called a rotary cutter. Manual vs. electric, but much easier to use and makes a nice cut. Just resharpen when the blade begins to dull. Ann said you can buy these at Joann Fabric, many different styles to choose from.
    Not a woodworking tool, but much less expensive, I suspect.
    --MJ
    "We didn't lose the game; we just ran out of time."--Vince Lombardi
    MJ, are the rotary cutters able to cut through solid plastic like acrylic (Plexiglass)? I thought they were for soft goods only.
    Inside the Beltway
    2,666
    Dietrich,
    I have bandsawn, drilled, routed and tablesawn the 'plexiglass' they sell at the orange borg. It's not the most pleasant work in the world, but it works. I suggest you get a piece of whatever you're thinking of, try it, and report back the results...
    Bill
    176
    Hi Vaughn,
    That's what Ann said, and she's the quilter. I just paint, carve, collage and play with tile.
    --MJ
    13,467
    I've tried routing the acrylic on my cnc router, it gummed up pretty bad after a few minutes. However this was using a 1/8" rounded bit cutting about 1/8" deep, so if your cutting away material it may not build up as bad.
    Kentucky
    7
    Quote Originally Posted by Dietrich Trenner View Post
    I want to make patterns out of acrylic...
    My suggestion would be a scroll saw. You have a wide choice of blades and can control the speed. Just a thought from a new member
    Hey Tim, welcome aboard.
    Westphalia, Michigan
    955
    Tim, you might try a router bit that has radial flutes. (twist) They would give you a shearing cut. Personaly I've used a scroll saw and a sander to fine tune the edge.
  1. Slimline/Acrylic
    By Bill Arnold in forum Lathe Project Showcase
    Last Post: 09-12-2014, 04:10 PM
  2. Replies: 12
    Last Post: 02-08-2011, 11:36 PM
  3. My first acrylic pen
    By allen levine in forum Lathe Project Showcase
    Last Post: 04-11-2010, 12:36 PM
  4. new acrylic box
    By George Watkins in forum Lathe Project Showcase
    Last Post: 07-07-2009, 10:26 PM
  5. 1st Acrylic Pen
    Last Post: 04-30-2009, 05:40 AM
