Results 1 to 5 of 5
Thread: Quick & EZ Smart Table
    3,134
    I had a piece of plywood just the right size in the storage shed & some 3/4"x3" plywood strips already ripped so I glued & pocked screwed them to the bottom of the top 2" in from the edges & ripped some 3/4" old AC into 3" strips for the sliding pieces. I figured they will be wasted so why get fancy. The straight pieces are a bit hard to slide but the corner pieces would fall out is I tipped the table. Over all not to bad though. It makes a 4'x5' top.
    30,014
    Bart, are the black strips some type of metal track? Looks like it should be a handy addition.
    5,321
    Interesting, Bart. I just ordered the parts to make mine yesterday. I plan on just putting mine across two sawhorses, instead of making a complete table, though.
    That's the set-up I've been using to break down sheet goods. It is surprisingly stable even when heaving MDF around on it.
    One step closer!
    Wes
    Monroe, MI
    470
    That's pretty much how mine is, except that I have 2 straight ones that like to fall out too. What I did was cut some small 1-1/2 L x 3/4 W x 1/2" T tabs from some scrap oak. I loosely attached them to one end of each slide, just above the slide with one screw. Flipped up, I can slide the slides in either direction. Flipped down they won't slide past the table.
  1. Quick question about finishing a table top
    By Roger Tulk in forum Finishing School
    Last Post: 12-08-2013, 02:17 PM
  2. Smart Phone Stand - Quick Christmas Gift Idea
    By glenn bradley in forum Flatwork Project Showcase
    Last Post: 10-26-2013, 06:05 PM
  3. Quick & Dirty SawStop Outfeed Table
    By Stuart Ablett in forum Jigs and Fixtures
    Last Post: 09-23-2011, 03:07 PM
  4. Quick-release router table?
    By Joseph Shaul in forum Jigs and Fixtures
    Last Post: 12-16-2009, 03:29 AM
  5. quick table
    By Al killian in forum Flatwork Project Showcase
    Last Post: 04-28-2009, 12:17 AM
