Results 1 to 10 of 11
Thread: Forrest 30 tooth TK
    2,784
    Forrest 30 tooth TK
    Just saw this on BT3 and ordered one. Thin Kerf 30 tooth WWII. Good price 58.87 free shipping. http://www.amazon.com/gp/product/B000ONEMRU Not sure if it's a 2 hour special or not. If so, it might just about be over. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    How does this compare with the 40-tool WWII blade which is also on sale at Amazon?
    2,784
    Porter, the 30 tooth, while still considered by most to be a combination blade, lt leans more to the ripping blade (24 tooth) than the 40. The 40 is the truer middle of the road combination blade. If you only have one blade, then the 40 would be better. If you have a 50 tooth combination blade, or a 60 or 80 tooth crosscut blade, then a 24 rip blade or 30 tooth combination blade would be a good blade to go with it. With a 24 and an 80, you would have the best of both worlds, but should change blades for each type of cut. The combination blades give you the compromise of both worlds, and the number of teeth give you an indication of which end it favors. This is a very generalized synopsis of the blades. Hope it helps. And keep in mind,if you have a contractor saw, the thin kerf will work fine. If you have a 3 hp cab saw, you would probably be best served with the 1/8" kerf, or full kerf, blade. Hope this helps and is not too late. Most do recommend the stabilizer to go with a thin kerf. I'm going to try it without and see how it does, both cut and noise wise. Jim.
    Exclusively Irish!
    Rochester
    846
    Quote Originally Posted by Porter Bassett View Post
    Hi Porter - I've got the TK version of both, and find it very difficult to tell the quality of the cuts apart. Even crosscuts with the 30T are reasonably good. The 30T has a notable advantage in feedrate and lower drag on the motor when ripping in thicker stock. I heavily prefer the 30T to the 40T, especially in hardwoods, and have been recommending it over the 40T in many cases. I get glue ready edges, and rarely need cleaner cuts. If cleaner crosscuts are needed, like with fine veneered plywood, blades like my 60T Infinity 010-060 Hi-ATB are an excellent compliment to it. YMMV.
    Got Wood?
    Sacramento, CA
    1,367
    Jason Beam
    Sacramento, CA
    2,784
    Another drop!! 52.84. I just applied for my second 30 day price match. I've saved 5.73, or almost 10%, after buying it. That never happens for me. Jim.
    Exclusively Irish!
    Quote Originally Posted by Jim O'Dell View Post
    Jim,
    Amazon description says that this is a circular saw blade. Is it okay to be used in the table saw? I am wondering if I can use it in my Delta contractor saw.
    Thanks
    2,784
    It is a 10" 30 tooth, thin kerf saw blade. Amazon uses the word circular, and most of us think hand held circular saw. But it's for the table saw. Jim.
    Exclusively Irish!
    Jim, thanks. Now it makes sense. Ordered one.
    2,784
    Another price update.....
    Ok, this blade has dropped again. Now at 50.20!! Get your refunds while they're hot!! Jim.
    Exclusively Irish!
  1. Smoker with Blue tooth control
    By Don Baer in forum The Cook Shack
    Last Post: 01-25-2016, 07:42 PM
  2. 50 Caliber Tooth Pick Holders
    Last Post: 01-08-2012, 02:26 PM
  3. Skip Tooth Bandsaw blade
    Last Post: 07-29-2009, 12:54 AM
  4. Brass Bullet Tooth Pick
    Last Post: 04-24-2009, 03:44 AM
  5. Hitachi 726100 12-Inch 60 Tooth
    By Steve Clardy in forum Hot Deals
    Last Post: 09-08-2007, 08:46 PM
