Results 1 to 10 of 19
Thread: New Grinder Wheels
    New Grinder Wheels
    The first time I put new grinder wheels on the slow speed 8" grinder, I went with the OneWay wheels, a #80 and a #120. They were very good, no complaints, but this time around, I went with the Norton 3X wheels, this time a #46 and #80. I found that the #120 wheel was not of much use, it loaded up a LOT in use, and I found I did not use it much.
    I did use the heck out of the Oneway wheels, they ended up being 6" in diameter, so I certainly did get my money out of them.
    The old wheels, just about 6" now.
    To show the amount of wheel that has been ground off.
    Here is one of the new wheels.
    One thing I did notice about these wheels is that I had to move the balancing nuts a lot further off the center to get them balanced, than the Oneway wheels, does that matter
    Nice to have new wheels!
    Goodland, Kansas
    4,834
    Thanks for the info Stu. I was thinking of the Norton wheels also. I found the same thing that my 120 wheel did load a lot. I had to true it all the time. Let me know what you think of the new wheels.
    Bernie W.
    Albuquerque, New Mexico
    1,099
    Stu, I have the one-way balancing system (beautiful way to balance your wheels!) along with the Norton 3X, 80 and 120 wheels. Obviously, not being a turner, I don’t dress the wheels anywhere near as often as you do, but I have found the 80 and 120 wheels perfect for touching up endmill’s, tool bits for the lathe, and sharpening drill bits. Carbide eats them up rather quickly though, I need a diamond grinder…
    friend...if you have one."
    one."
    Bernie, I used the wheels a little, and they seem to work fine, but I'll keep you updated.
    Bruce, I've got that Oneway balancing set up as well, it sure was worth the money, my cheap Woodcraft slow speed grinder, runs nice and smooth!
    11,833
    The wear on that wheel is amazing. I have inherited grinders that are older than I am and the current size is probably not measurably smaller than the original 8". I just measured my Camel brand, Israeli made, 80 grit blue, 8" wheel from WC. It is six years old, used daily and still measures a full 8". As said, the carbide must be very hard on your wheels. Methinks, for carbide, one would get diamond grit wheels. Expensive, but, what the hey, who worries about money?
    Carbide???
    I use it to sharpen my lathe tools, which are all HSS.
    Thing is Frank, I sharpen all the time, I work mainly hard wood, the "Zelkova" and it dulls the tools quickly, also, to be fair, I was doing a lot of learning on those first wheels, so
    I've got my jigs built and my technique down now that I'm sure the new wheels will last a lot longer.
    Drums, PA
    292
    What you need now is a second grinder, one that uses 6" wheels.
    Sep 2007
    613
    Stuart, I think you don't need a balancing set so much on a slow speed grinder, isn't it.
    Also I thought that you would go for a belt grinder sometimes, or am I wrong.
    Ad
    Red Deer, Alberta, Canada
    618
    Stu, I was about to order a pair of wheels from Oneway. Am I correct in assuming that you'd recommend the coarser wheels? What grit do you recommend? Or should I wait until you've tested the Norton wheels more extensively?
    Thanks for the information, Stu! Much appreciated.
    11,833
    Carbide???
    I'll still stick with the "amazing" part. Considering that I have these 80 year old wheels my father used in his professional shop, then home shop before I got them and they are still 8", the wear on yours is definitely "amazing".
  1. wheels for my 6 inch delta grinder?
    Last Post: 06-13-2014, 04:55 PM
  2. Just some wheels
    By Chuck Thoits in forum Flatwork Project Showcase
    Last Post: 05-05-2011, 01:53 AM
  3. Cup grinding wheels in a bench grinder?
    By Eric Roberts in forum Old Iron
    Last Post: 09-08-2010, 03:58 PM
  4. Diamond Wheels for Your Grinder.........??
    Last Post: 04-27-2008, 02:50 PM
  5. wheels down.
    By Keith Williams in forum Welcome and Introductions
    Last Post: 05-20-2007, 04:33 PM
