Results 1 to 4 of 4
Thread: kreg pocket hole jig dust collector
    Topeka KS
    118
    last night i hooked up the dust collection port on my kreg jig and i was amazed at the results. without the dust collector the jig makes a huge mess, the shaving ports get clogged up and the drill bit struggles to make the cuts. with the collector hooked up theres absolutely no mess at all and the drill bit goes right through like butter.
    my shop vac has a 2-1/2" hose and the kreg port is much smaller and since i didnt have an adapter i had to figure out a way to hook it up. i ended up using some pvc pipe and a tapered attachment i had and taped it all together. its ugly but it works fine
    if you have an older kreg jig you should do yourself a favor and get the vacuum attachment for it!
    Als ik kan
    Sacramento, CA
    1,367
    Nifty, ain't it, Mike?
    Too bad that attachment won't fit on the K2000, though. But I HAVE seen somewhere out on the internet someone built a baltic birch plywood box around it with a vac port that they claimed worked really well. So all hope is not yet lost for the K2000 users!
    Jason Beam
    Sacramento, CA
    Toronto, Ontario, CANADA
    2,332
    Quote Originally Posted by Jason Beam View Post
    Jason, that might have been me. In February 2006, I made such a box and posted this description:
    A little while ago, Ethan was “helping” me drill some pocket hole holes and he observed that we were making a lot of chips. Once we had finished, he spent considerable time attempting to gather the chips and dust up. This encouraged me to make a little “house” that pressure fits onto the pocket hole jig and into which I can fit a shop-vac hose. It really works well. Ethan agrees!
    and photo:
Name:	Dust collector on Kreg jig -small.JPG
    on at least one forum:
    Cheers, Frank
    Sacramento, CA
    1,367
    Well heck, Frank. That's the one! Thanks for jogging the ole' memory
    Jason Beam
    Sacramento, CA
  1. Kreg Pocket Hole Screws
    By Charles Hans in forum Hot Deals
    Last Post: 01-28-2012, 04:29 PM
  2. Kreg Pocket Screws and Bits question
    By Bob Wiggins in forum General Woodworking Q&A
    Last Post: 01-15-2009, 12:37 AM
  3. $86 after $20 rebate Kreg K3 Master Pocket Hole System
    By Bob Luciano in forum Hot Deals
    Last Post: 07-29-2007, 07:36 AM
  4. Kreg Pro Pack Pocket Hole Set
    By John Stevens in forum Old Ads
    Last Post: 03-07-2007, 11:42 PM
  5. Chip collector for older Kreg Pocket Hole Jig
    By Frank Pellow in forum Jigs and Fixtures
    Last Post: 11-09-2006, 01:54 PM
