Results 1 to 7 of 7
Thread: Keeping the curlies in control.........
    ......or at least trying to keep them in control....
    Like a fair number of turners, I have my lathe against a wall, this makes cleaning out behind the lathe time consuming and just not fun.
    When I had the lathe in the old location, I made a back board, that was sloped from the wall to under the lathe, so cleaning up was a lot easier.
    I've done the similar thing now, but with a few improvements.....
    I've also made it in two pieces, there is one piece that is attached to the lathe, and the other piece is attached to the wall, this way, if I have to move the lathe, I can easily, I can also easily remove the piece that is attached to the wall, if I need to get at the storage under the backer board.
    Another view.
    I put an end board on as well, hoping to keep more of the curlies in control
    Took it for a test run, works great!
    Then to clean up, I just sweep the curlies down into the waiting garbage bag.
    easy as that. it will not stop the curlies from reaching the floor in front of the lathe, that is still going to happen, but this set up will sure make cleaning up a lot easier!
    Just thought I'd share.
    13,460
    Stu,
    Looks like that is working well. I was looking at doing the same but having an opening in the middle of my bench that the backer board sloped down to, then putting a collection box underneath. That way I could sweep off the bench into the opening, or eventually hook the DC to it.
    Goodland, Kansas
    4,834
    Great idea Stu. Looks like it works well.
    Bernie W.
    Darren, hooking up your DC to the curly collection box would just make a lot of work emptying the DC, IMHO, for sanding, sure, but for roughing out, now way, a shovel and a broom work just fine
    Jul 2007
    Des Moines, IA
    854
    Stu, I like what you did very much. Hope you don't mind if I try it.
    Quote Originally Posted by Wayne Bower View Post
    Sure thing Wayne, but you got to post pics
    Central Illinois
    936
    Looks ike one of the best solutions I've seen in a long time.
    Bruce
  1. curlies
    Last Post: 08-22-2009, 03:25 PM
  2. keeping cool
    By Dave Hawksford in forum Shop Tours
    Last Post: 04-28-2009, 11:06 AM
  3. Is is worth keeping??
    By Royall Clark in forum General Woodturning Q&A
    Last Post: 11-03-2008, 12:20 AM
  4. Sawdust and curlies
    By Westley Rosenbaum in forum General Woodturning Q&A
    Last Post: 07-14-2008, 07:41 PM
  5. gardening - from sawdust and curlies
    By Mark Kosmowski in forum Off Topic Discussion
    Last Post: 06-06-2008, 05:40 PM
