Results 1 to 10 of 13
Thread: Hand Wheel
    Nov 2007
    Nashville, Ar.
    53
    Hand Wheel
    Could someone explain what to purpose or advantage to having a haand wheel on the lathe. Seems like a sort of a dumb question. I've read various comments about them but never any real information as to there use. Boy, it's fun to be a newbie. Jack
    Lots of reasons Jack, I use mine every time I'm on the lathe, first, I use it to help crank on a chuck to the spindle, instead of spinning the chuck onto the spindle, I spin the handwheel, spinning the spindle into the chuck, I find this much easier, especially if there is a large or even medium turning attached to the chuck. I also use my handwheel to slow down and stop the lathe (once I hit the off switch) to look at something on the turning, say I'm checking for thickness etc. I don't like standing around waiting for the lathe to stop turning. My DVR with even a medium sized turning on it can take a while to spin down.
    Nov 2007
    Nashville, Ar.
    53
    Stu,
    Thanks for the reply, I hadn't thought of those ideas. I bought a hand wheel for my Nova 1624-44 when I ordered it, but wasn't sure what the need for it was. Thanks again, Jack
    North West Indiana
    6,097
    Yep, everything Stu said. Make sure it has no burrs on it.
    Seem to get less splinters slowing down my lathe using the hand wheel rather than the turning!
    11,825
    My woodturning club had a professional turner as a member. He didn't consider a lathe a lathe unless it had a hand wheel. And, he wouldn't use a lathe without one.
    My Grizzly has this spindle thing sticking out the back. Normally, it is hidden by a safety shield. I raise the shield and turn a rough block to make sure it clears the rest before hitting the power. Also I use it to turn work while I am hand sanding, particularly lengthwise. Other than that, I can't think of a reason why it is even there.
    30,008
    My previous lathe had no hand wheel, and I learned to work around it. My current lathe does have one, and it does come in handy. In particular, I find it makes screwing a large faceplated blank onto the spindle much easier. I can hold the blank in position cradled in my right arm, and turn the hand wheel with the left hand to thread the blank onto the spindle. It's easier to keep the threads lined up that way, instead of trying to rotate the blank itself.
    Decatur, Illinois
    177
    frank, i'm not familar with the grizzly lathe but one reason to have 'something' at that end of the spindle might be to provide a connection for vacuum chucking. my nova only has a female thread at this end so i bought the optional handwheel (a metal turning but too small for using as a normal handwheel) and turned a walnut handwheel that screws to this metal one. i use it to stop rotation quickly because i'm too impatient to wait...to rotate the spindle as vaughn described to load a chuck.
    99% of lawyers give the rest a bad name...Steven Wright.
    868
    I take it, there is no crank handle on these hand wheels. My Delta/Rockwell has an LH thread on the outboard, so I've made some face plates utilizing a 1" LH nut.
    I'm thinking of putting a handle on the hand wheel but I can visualize the handle spinning at 100 MPH. What diameters are your hand wheels?
    Mack C. in Brooklin ON
    It feels great to sell a pen,
    I am a proud supporter of
    Jan 2008
    Stow, OH
    151
    It is also useful if you use the indexing. It is easier to visualize the rotation on a hand wheel than a small spindle. You don't want to grab a fragile turning and rotate it for inspection.
    Only the engineers at Grizzly would put a disk sander there in place of the handwheel, for manicure or removing the rough callus of left palm? to block the use of the knock out bar? to use through the hole vacuum chucking?
    Clark,
    I am not familiar with the Nova 1624 handwheel. If it is the same as the DVR, the recess in the handwheel just fits a popular size bearing, and there is already a set screw hole there for you to lock the bearing in place. I just use a piece of gasket between the handwheel and the outer race of the bearing. The vacuum force would hold the home made vacuum adapter together, no lamp rod needed. It is a easy on and off.
    Gordon
    11,825
    Gordon said, in part, "Only the engineers at Grizzly would put a disk sander there in place of the handwheel, for manicure or removing the rough callus of left palm? to block the use of the knock out bar? to use through the hole vacuum chucking?"
    Gordon, as you know, I'm pretty much a fan of Grizzly. But, I do have to admit that some features on their tools says to me that some of their (Chinese?) engineers really do not understand the function of what they are designing. Methinks they are given specs and draw up the machine and go from there. Having an old timer curmudgeon, like us, there, before final approval, would make for much better tools.
    Of course, this is true for a lot of things. On American cars, I have often wondered if anyone actually tried driving those things before selling them to the public.
  1. New 5th Wheel Rig
    Last Post: 06-10-2015, 04:12 PM
  2. Which Dry Grinder Wheel
    By Jim C Bradley in forum General Woodturning Q&A
    Last Post: 01-04-2013, 06:04 PM
  3. HAND WHEEL for HF Lathe
    By Paul Douglass in forum General Woodturning Q&A
    Last Post: 08-01-2012, 02:47 AM
  4. getting a steering wheel off
    Last Post: 10-13-2010, 05:14 PM
