Results 1 to 10 of 19
Thread: Cyanoacrylate glue vs super/krazy glue, loctite glue, etc
    Topeka KS
    118
    been searching for "CA Glue" high and low nowhere to be found locally except normal super glue which if you read the ingriedient list contains Cyanoacrylate. my thinking is these are one and the same but I see everyone using actual bottles marked "CA Glue" and everyone calls the glue by this name vs the more familiar super glue or krazy glue. i know those names are brand names but they are kind of like kleenexs. nobody i know calls them tissues...
    so is there some secret super special "CA Glue" out there specifically for woodworking or will any glue containing Cyanoacrylate work?
    Als ik kan
    Each of those are brands of Cyanoacrylate. All of them contain Cyanoacrylate in one form or another some are more pure and have different thinners and chemical additives some are gel and others are thinner than water. Yet all are CA. Most call it CA because they don't want to identify the brand (the reason that the TV shows say CA as for the rest of us it is an excepted way to discribe Cyanoacrylate because most of us can neither pronounce nor spell Cyanoacrylate (thanks to spell check I have a good repensation of Cyanoacrylate in this post) CA is easier. I personally prefer the cheapest from Dollar Bills or Dollar Tree store for finishing or wood filler but for strength I order Rhino (which is a real Super super glue) www.rhinoglue.com . Which is not to be confused with Super Rhino glue which is a Polyurethane glue onder a similar label by a different manufacturer.
    Cedar Park, TX
    320
    Like you've discovered, there are a bunch of brands out there as well as formulations. It's all the same basic stuff. There is some specifically formulated to work well on wood, but you'll either have to order it or pick it up at a woodworking store. Of the brands available at the regular stores, I've found the Loctite brand to work best with wood.
    The larger bottles of the stuff seem to go bad before I can use them up. The glue takes longer to harden as it gets old.
    Jerry
    Decatur, Illinois
    177
    jerry makes reference to ca glue going bad...i saw somewhere the instructions to keep the glue in a glass jar with a small bag of the drying dessicant (sp?). i'm doing this with a zip lock bag that i can hang on a hook. we'll see if it works.
    99% of lawyers give the rest a bad name...Steven Wright.
    Cedar Park, TX
    320
    I bought one of those CA glue "kits" from Rockler or someone. Two bottles of glue, a bunch of spare tips and a clear plastic jar with a screw on lid to keep the bottles of glue in and out of the regular moisture in the air. Of course that means you gotta remember to put em back in the jar when you're finished using em, so I don't know if keeping em in there would have prolonged their life or not.
    Jerry
    Fort Washington, PA
    180
    I use CA in the woodshop almost exclusively for making jigs or when I want something to bond instantly (actually takes about 3 seconds) in which case I spray on the accelerator. Also use it often for gluing a shorter sacrificial piece of 1 1/2 inch dowel onto a longer one to facilitate running it through the Bealle threader. I too have had my last two 8 oz bottles go bad before I finished them, so won't get that large a quantity again.
    Build it Break it Fix it ...repeat
    Westphalia, Michigan
    955
    Mike, I get my CA glue from woodenwonderstx.com They have the best price I've found.
    Cedar Park, TX
    320
    Everyone knows how badly MDF takes to regular wood and sheetrock type screws. I use MDF sometimes for jigs but can't see the expense of stocking any assortment of sizes of the special MDF screws to have them on hand. But I have found the if I drill pilot holes, then run either a regular wood or sheetrock type screw into the hole to "tap" it, remove the screw and add a drop of two of thin CA into the hole and quickly run the screw back into the hole, the CA does a nice job of hardening the threads. Since CA does not stick real well to the screw, you can break it loose from the threads if need be, and the threads remain pretty much intact.
    Also works pretty well as a substitute for loctite on machine threads if you don't have that handy in the shop.
    Jerry
    Long Island, NY
    71
    You can find CA glues in hobby stores, they come in thin, medium, thick and gel. You will also need the accelerator.
    Richard
    Mar 2010
    SW MN
    34
    My method in preserving super glue is a small compact refrigerator. Keep the setting low and I have some superglue stay good for years---that is a good value move because such a unit costs no more than an assortment of glues----and how nice is it have some cold adult beverages on hand?
  1. Will super glue stick to lacquer?
    Last Post: 05-31-2012, 01:54 AM
  2. CyanoAcrylate Glue Finish for Pens
    By Brent Dowell in forum General Woodturning Q&A
    Last Post: 10-26-2008, 02:32 AM
  3. CyanoAcrylate Glue - Removal
    Last Post: 10-19-2008, 03:26 AM
  4. Thinned Super Glue
    By Shawn Lakes in forum General Woodturning Q&A
    Last Post: 03-18-2008, 03:39 PM
  5. OK, now the glue?
    By Chuck Hanger in forum Turning Tool Questions and Show & Tell
    Last Post: 04-27-2007, 03:12 AM
