Results 1 to 10 of 12
Thread: Can your plywood do this??
    The Heart of Dixie
    4,268
    I ran out of space on the outfeed tables so I had to move it out of the way.
    Custom built boats and Kits
    Excellant example of Creative Problem Solving and Workshop Limitations Counter Engineering
    That pretty much explains how you're gonna be able to bend the pieces of the kayak. How thick is it? Is it special "bending ply"?
    The Heart of Dixie
    4,268
    It 3mm Okoume marine plywood. Not bending ply, just very thin. It's hard to do anything with a full sheet it's so floppy. Thought about tying it in a knot and taking a photo. But this worked just as good.
    Before you ask Okoume ( o-KUE-me), also known as Gaboon, is an African hardwood widely used in Europe over the past century.
    Buse Township MN
    565
    Pretty nifty, but I saw some 3/4" birch "cabinet grade" ply at Home Depot the other day that was even more curved than your piece
    Every child deserves a family. Adopt. Foster. Get involved.
    At the shop we call that wood "wacky wood", since you can bend the stuff into a pretzel. Its pretty neat stuff. They have some other cool plywoods too like plastic cored plywood, which is this honeycomb looking plastic webbing inside two layers of birch veneer plywood outer cored. Most of it is to reduce weight so the boats go faster in the water? When you get into marine plywoods, you can run into some unique stuff.
    Heck, I hear you can drive forklifts over that stuff with out any damage
    Cedar Park, TX
    320
    Surprised no one else mentioned this, but it looks like that long piece is made from three shorter pieces joined on end. What sort of join and glue did you use that allow that to bend like that without breaking?
    Jerry
    The Heart of Dixie
    4,268
    A scarf joint. Basically a very long bevel cut on the ends and then glue them together. Here is something I found that shows it pretty well.
    http://www.naese.com/scarfing.htm
    Cedar Park, TX
    320
    Yeah, I know scarf joints, just couldn't really see well in the pic. I used scarf joints to make longer some 8' long ply into 15' long ply for a pirout I made several years ago, but I don't know that I would have trusted the joints to hold with that much bend.
    Since this is for a boat, presuming that you used epoxy for the joint?
    Jerry
  1. Segmented and Plywood box
    By Jim Krager in forum Lathe Project Showcase
    Last Post: 06-13-2011, 05:25 PM
  2. Plywood (from where)
    By Paul M Cohen in forum Carpentry and Construction
    Last Post: 05-30-2008, 02:38 PM
  3. Arauco Plywood
    By jim crockett in forum General Woodworking Q&A
    Last Post: 05-16-2008, 07:20 PM
  4. Bamboo Plywood
    By Erik Monson in forum General Woodworking Q&A
    Last Post: 02-26-2008, 03:44 PM
  5. Plywood
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 03-21-2007, 02:29 AM
