Results 1 to 10 of 11
Thread: PC 892 Fixed Base at Amazon $160
    Cedar Park, TX
    320
    Don't know if THIS is a really hot deal or not, but I've seen the motor alone for more. You gotta add to your cart to see the price, but you can not ooder or dump it or whatever.
    Jerry
    Field, Ontario, Canada
    113
    Sounds like a deal to me.
    The Plunge/Fixed Kit is also on sale for 250$. Apparently half price!!!
    Thanks for the heads up.
    Anything that can go wrong will go wrong, so keep your hands away and watch out!
    Cedar Park, TX
    320
    I've got the 690 series plunge/fixed kit with the fixed base in the router table presently. Thinking of putting the fixed 892 in the router table for the extra HP and variable speed and using the 690 for hand held.
    Jerry
    Tokiwadai, Japan
    2,882
    I would probably go this route...http://www.amazon.com/Bosch-1617EVS-...5966941&sr=1-7 I have heard that the "8" series PC is not as good as the other PC routers. Might be worth a search for comments before you buy.
    (owns both 1617s and 690s and like them much)
    Cedar Park, TX
    320
    Someone over at Woodnet said that there had been some issues with the 8 series PC routers, and another fella advised that they had fixed the problem. Most of the issues involved the plunge base, but there have been some problems with the variable speed circuitry.
    That Bosch looks like a good deal, and they have a table mount base for it. I'd need to drill a hole in the cast iron router table extension on the table saw for above the table the adjuster, but that shouldn't be a problem.
    I noticed that the above the table adjuster for the PC went from $22 and change to $26 and change since yesterday, so the Bosch would be less than $20 more with the table mount base added in than the PC and adjuster.
    Jerry
    Tokiwadai, Japan
    2,882
    The Bosch 1617 fixed and plunge base set is $199 now...
    http://www.amazon.com/Bosch-1617EVSP...6027103&sr=8-1
    Villa Park, CA
    1,407
    I have the Bosch 1618EVS which is the 1617 with the "D" handle. The problem I see with mounting the Bosch in a table (if you use the standard Bosch base) is the way the fine adjustment works. On the Bosch, the fine adjustment is not continuous - you have detents to set the major location and then a screw that adjusts within a certain range.
    The problem is that occasionally you hit the end of the range and have to make a detent change. So as you're working your way into the right setting on the table, you can hit that end stop and have to start all over again.
    I also have the PC 890 and it has a continuous fine adjustment. That is, you can (if you want) adjust the height through the full range with the fine adjustment - you never hit a stop.
    I'm not advocating either one but I'd suggest you get a continuous adjustment router for use in a table.
    Mike
    Ancora imparo
    Cedar Park, TX
    320
    Well, Mike, I read your post too late. Ordered the Bosch with fixed base and got the last one at the cheaper price. Also ordered the under table base for it.
    Jerry
    Tokiwadai, Japan
    2,882
    Jerry,
    I think your are going to really like the Bosch. Once you use it, setting the "course" position will come easy. You can then fine tune it from above or below.
    Cedar Park, TX
    320
    The above the table adjuster requires a hole drilled in the tabletop and since it will be mounted in my cast iron router extension table of the Griz, I may try it for a while just using the lower adjuster.
    Jerry
  1. Jet 16-32: fixed
    By Steve Southwood in forum New Tools
    Last Post: 07-03-2010, 11:12 PM
  2. WTB Porter Cable 690 Fixed Base
    By Ned Bulken in forum Old Ads
    Last Post: 08-16-2009, 02:29 PM
  3. Fixed base or plunge router question
    Last Post: 05-11-2009, 01:47 AM
  4. Replies: 10
    Last Post: 04-11-2009, 06:22 AM
  5. Replies: 2
    Last Post: 04-07-2008, 01:21 PM
