Results 1 to 10 of 13
Thread: Laquer over bare maple?
    St. Clair Shores, Michigan
    11
    Hi, I'm new here.
    I'm about to spray on clear gloss laquer over finely sanded hard maple (no stain). Is there anything I should be concerned about or any precautions?
    I've built a top for a dining room buffet; in order to match the rest of the diningroom set I need to blow on a high-gloss clear laquer. I'm a little nervous about messing up about $200 worth of maple
    THANKS!
    Welcome aboard, Michael. I've used lacquer on turned maple pieces, and can't think of anything to warn you about. There are others here who know more about furniture finishing than I do, so I'll be interested to see what others might say.
    Welcome to the Family Michael!
    Do you not have any scraps left over?
    I agree with Vaughn that there should be no issues, but I also agree that I'd not want to have to start over on $200 worth of wood.
    Sand the scrap piece the same way you have the table, then try finishing it, and see what happens?
    You might want to put a thinned coat of the finish on first, it will go into the wood and seal it up, so the next coat will not take as much product to cover it, the thinned coat will cost less than a regular coat (thinner is cheaper than Lacquer).
    Lightly hand sand between coats, and make sure you really clean up the dust before you put the next coat on.
    Good luck.
    Stu
    squirt it.......there`s no finish more workable than lacquer, it can be recoated as many times as you like or buffed to any sheen you desire.
    11
    Laquer
    Thanks for all the information/suggestions... and for the welcome too!
    Stuart, yes, I do have some scraps left. I don't even know why I didn't think about that. Just nervous about the upcoming spray-on I suppose.
    Tod, can I buff the laquer with a random orbital buffer (the kind you use to polish a car), and do you know if the procedure is about the same, and should I let the laquer cure for a couple weeks first?
    Working the wood isn't so much the issue with me... the chemistry is the issue.
    Quote Originally Posted by Michael Ward View Post
    yup, and the 3-m compounds work well....it`s just messy and time consuming.
    9,077
    If I missed your first post, Welcome! I try to never apply a finish unless I know how it will act. Shoot a piece of scrap BUT, be sure the scrap has been sanded, etc. just like your top. It doesn't tell you much to test a finish on a piece of material that has been prepared differently. I make test boards and jot the sanding prep and finish protocol on the back for future general reference.
    P.s. I would take Tod's advice in a heartbeat.
    London, Ontario
    3,383
    I finished this dresser with brushing lacquer over "bare" maple and cherry. worked great.
    Austin, Texas
    1,448
    I do it all the time... no problem.
    I have migrated to Target USL water base lacquer... still gives full burn in, but is even easier and more durable than the traditional nitrocellulose lacquer.
    See www.plesums.com/wood/tips/finishing.html I am in the process of expanding the tutorial for my other site... if you have questions, drop me a note and I will be sure they are covered.
    Charlie Plesums, Austin Texas
    11
    SUCCESS!!!
    Success!
    I want to thank you all of you who gave me advice! Here is the end result. Remember, I ONLY built the top to this buffet.
    Thanks guys. I couldn't have done this without you and your knowledge.
    The guy I made this for was very happy too.
    (This was my first attempt at a piano finish. Hopefully the next one will be even better.)
  1. Bare Naked
    Last Post: 01-29-2016, 06:53 AM
  2. Bare Minimum to get Started with Small Hollow Forms
    By Brent Dowell in forum General Woodturning Q&A
    Last Post: 11-08-2008, 10:06 PM
  3. First Time Trying Rattle-Can Laquer
    By Gord Rock in forum Finishing School
    Last Post: 04-27-2008, 12:29 PM
  4. Varnish and Laquer
    By elliott azis in forum Finishing School
    Last Post: 04-09-2008, 02:23 PM
  5. Pre catalyzed laquer
    By Steve Ash in forum Finishing School
    Last Post: 11-20-2006, 10:10 AM
