Results 1 to 10 of 16
Thread: My new Bandsaw....
    5,533
    My new Bandsaw....
    in addition to my new spinny thing, I picked up a tuned up HF bandsaw, with riser block, link belt, extended crank tension adjuster and hefty shop built base:
    the base is Solid... 3/4" MDF with DC port installed.
    Should do the job until the budget allows for that minimax someday
    -Ned
    Congrats Ned! May it serve you well!
    Ken
    5,533
    Thanks Ken,
    over on woodcentral someone pointed out that the fence is an aftermarket unit, and a quick call to my friend confirmed this, it is a Fast-trac fence, which sold out to Kreg and now the same (or similar) model is sold as the Kreg fence.
    -Ned
    17,470
    Paint it mustard yelo
    then it work just as good as the pricey ones ned or white with blue trim like kens congrats have a old atlas that is older than you are and its only 12" so you got a bigger one than me..
    5,533
    Thanks Larry, funny you should mention painting it. I was actually thinking of a new color for it, figuring that I'd take a page from Vaughn's book and make my own 'brand' of Saw someday.
    -Ned
    Odessa, Tx
    1,813
    Congrats on the new Toys, Ned. Now get them "Long Johns" on and finish that "ROOF" so you can use 'em.
    Tokiwadai, Japan
    2,882
    Ned,
    Couple Qs....
    What's the "Gear Crank" on the saw table top for? Blade tensioning?
    Is the top original? Seems to have a nice polished finish to it, and appears to be quite large...
    Nice fence too... Optional or 3rd party maker?
    I think a good cleaning and maybe a white paint job..with some thin trim, would really look nice, but....it looks like it will work fine for right now...
    Rio Rancho, NM
    1,417
    Congrats on the new saw, Ned.
    Larry, what vintage is your Atlas?? We also have an old Atlas, inherited from my father-in-law who bought it new in about 1952, together with an Atlas lathe. He got the two machines for about $75.00 then, paid them off $5 at a time when he could shake the money loose. We put new tires on it about a year or so ago---the first new tires it had had (obviously FIL didn't use it very much, but we sure do).
    Nancy
    Nancy Laird
    dandnspecialties@msn.com
    5,533
    Quote Originally Posted by Greg Cook View Post
    Ned,
    Couple Qs....
    that's the tensioner, with extension to clear the top of the saw, aftermarket. A zoom in in photoshop says it is a Quick-Crank. (removed to avoid damage on the way home)
    the original owner had serious upgrade-itis.
    the top is a clamp on formica cut-out, and the fence is a Fast-trac aftermarket fence. Fast-trac was bought out by Kreg, and that's essentially a silver Kreg bandsaw fence.
    good cleaning is about all it will get until I'm much more settled in the shop, someday this summer. Though a good paintjob Might just happen sooner than that...
    -Ned
    30,002
    Quote Originally Posted by Ned Bulken View Post
    ...Though a good paintjob Might just happen sooner than that...
    Through extensive research, I've determined that purple saws cut faster. (Although I used some of the black "hammered finish" Krylon a while back on a metal cabinet, and it's got a cool look, too.)
    Congrats on the saw, Ned. The cast iron parts sure looks the same as every other 14" import bandsaw I've seen, including my Shop Fox.
  1. Bandsaw Box
    By Bob Gibson in forum Flatwork Project Showcase
    Last Post: 03-25-2014, 07:52 PM
  2. Bandsaw
    Last Post: 07-05-2009, 03:45 AM
  3. bandsaw box
    Last Post: 06-29-2009, 01:06 PM
  4. BIG bandsaw
    By Dale Johnson in forum Old Iron
    Last Post: 05-17-2009, 03:28 PM
  5. Need a bandsaw bad!!!!
    By Chuck Hanger in forum New Tools
    Last Post: 12-12-2007, 01:05 PM
