Results 1 to 10 of 13
Thread: Sheet Laminate Transportation Question
    I'm in need of some laminate for a router table and while my car is usually enough for the trips to the hardware store, I know that I can't fit a sheet of 4x8 laminate. Is this able to be rolled up into a loose roll, or am I better off getting enough of a purchase together to justify renting the truck from the borg?
    -Duane
    just roll it up........formica i assume?
    Tokiwadai, Japan
    2,882
    Duane,
    I recently renovated my computer loft and put laminate on my computer desk and side area. I got the laminate sheet at HD, rolled it up and put it in the back of my small car, with no problems.
    Attachment 18817
    Formica or Wilson Art, depending on which one I got too.
    Thanks
    -Duane
    Sacramento, CA
    1,367
    It'll roll up and fit in the back seat of my car - JUST barely. I wouldn't roll it any tighter than about 20" diameter - unless it's warm
    Jason Beam
    Sacramento, CA
    Inside the Beltway
    2,666
    Greg,
    You're cutting it on your ping-pong table? Doesn't that mess up people's serves?
    But seriously, is there some protection underneath we can't see?
    Bill
    Rolling sheet laminate
    Sheet laminate can be easily rolled. However, If I can make a recommendation...If you go to your local countertop shop...Ask them if they have Postform or V32 Grade. Thinner, no loss of duribility, and more importantly, less of the Backer sheet is visible. Much nicer looking.
    Good luck
    Jason
    Topeka KS
    118
    speaking of laminate sheets... whats the going rate for this stuff? lowes has a 4x8 sheet but its $45. i only need like 2x3 at the most for what im wanting to build. just seems awfully expensive. is there any other cheaper options for buying these things?
    Als ik kan
    What I used was a piece of white Melamine, Got it in the offcut bin at HD for a couple of bucks. Laminated it to a thicker MDF piece and made a sturdy top , slick as waxed snot and at much less the cost.
    A piece of precut countertop would serve as well and at half the cost of a sheet of laminate. (just cut the backsplash off) There are several alternatives for creating a nice Router table top.
    Tokiwadai, Japan
    2,882
    Greg,
    Bill
    OK, now I know why the ball goes going screwy somtimes....
    Bill, if you look very closely, just under the saw, there is a thin board between the table and the laminate. I adjusted the saw blade to just cut through the laminate and slightly "groove" the board.
  1. CNC job Setup Sheet
    By Leo Voisine in forum New Systems and Builds
    Last Post: 05-09-2015, 03:43 AM
  2. laminate top, am I missing something,
    Last Post: 02-09-2015, 02:48 PM
  3. trimming laminate
    By Guy Bratt in forum General Woodworking Q&A
    Last Post: 03-17-2013, 12:05 PM
  4. Free transportation! - Act quickly!
    By Rennie Heuer in forum Giveaways, Contests, and Swaps
    Last Post: 11-02-2010, 04:12 PM
  5. Veneer/laminate router related question
    By Westley Rosenbaum in forum General Woodworking Q&A
    Last Post: 04-10-2009, 04:13 AM
