Results 1 to 10 of 20
Thread: Windows power management question
    Albuquerque, New Mexico
    1,099
    I want to be able to power down my LCD monitor when I’m away from the computer. When I right click the “desktop/Properties/Screen Saver/Power/Turn off monitor”, and select 5 min the setting lasts for exactly two power up cycles then reverts back to “Never” mode.
    Is there a way to permanently set the computer to power down the monitor after 5 minuets of non-use? You’d think that that the desktop route would do it but it doesn’t.
    I’m running Windows 2000 Professional. (I know, I really need to get a new system…)
    Thanks
    friend...if you have one."
    one."
    The Heart of Dixie
    4,268
    w2k is an excellent OS. I dread having to upgrade to something else!
    I will ask the obvious. Have you rebooted in a while? Thats my best idea.
    Custom built boats and Kits
    1,099
    Jeff, I shut the computer down each night. When I boot up the next day (and the day after that) the computer remembers the power down setting but on the third day it reverts back to the “Never” mode and doesn’t shut the monitor off again.
    It’s very weird.
    one."
    Tokiwadai, Japan
    2,882
    Bruce,
    You might try just putting the computer to sleep for a week, rather that shutting it down, and see if it reverts back at some time. The timing, or cycle might give some more clues...
    FWIW,
    Elgin, IL
    442
    Bruce,
    Look under "Start,Settings,Control Panel,Power Options" and see you can change something there.
    Randy
    The attachment is from an XP machine but its very similar to an Win2K machine
    1,099
    Randy, that's pretty much the same win2k window that I am looking at when I follow the path “desktop/Properties/Screen Saver/Power/Turn off monitor”
    one."
    Up date your system
    Go to Microsoft web site and look for system updates. There are a least 3 service packs for Win2K. You will need to run them in order to ensure that you completely update your system. Them retry to set your requirements.
    Good Luck.
    John
    Elgin, IL
    442
    Quote Originally Posted by Bruce Page View Post
    Just a thought, is this a personal computer or a work computer? I know my work computer and work blackberry has system policies that are maintained by them.
    Randy
    Elgin, IL
    442
    Tek-Tips.com
    Check this post out and see if provides any help.
    http://www.tek-tips.com/viewthread.cfm?qid=950543
    Randy
    1,099
    Randy, it is my home pc. I read through most of the thread that you linked to but most of it is above my pc skill level. I started getting warnings eg., do you really want to do this? so I backed out.
    The power setting is really more of an annoyance than a problem, I’ll just continue to live with it for now.
    Thanks for your help.
    one."
  1. Windows, Muntin to Frame Joining Question
    By Bob Beasley in forum General Woodworking Q&A
    Last Post: 01-26-2016, 02:40 PM
  2. File Management Question
    By Bill Arnold in forum Programming, Troubleshooting, and Q&A
    Last Post: 10-24-2015, 05:31 PM
  3. Windows 10 Question
    By Paul Douglass in forum Off Topic Discussion
    Last Post: 09-24-2015, 01:57 AM
  4. 220 Power Question
    By Cynthia White in forum Carpentry and Construction
    Last Post: 11-04-2010, 05:42 AM
  5. Windows XP Pro Question
    By Bill Arnold in forum Off Topic Discussion
    Last Post: 08-19-2008, 03:18 PM
