Results 1 to 4 of 4
Thread: If your using the Worksharp 3000
    3,134
    But not using their proprietary abrasives what are you using & how are you sticking it to the glass plate?
    Thanks.
    3M 77 Adhesive...
    Spray it on, let it sit for a few minutes then come back and apply your sandpaper. I use it all the time at work to stick sandpaper to whatever I need to sand the places I need to get to. Aluminum rod, aluminum plate, etc...The stuff will stick sand paper to anything...even glass.
    If you have a hard time removing the old sand paper, 3M Citrus Adhesive Remover is great too. I have both cans will reach of me at all times at work.
    Jan 2008
    Austin TX
    405
    Bart,
    I purchased some 6" self-adhesive sand paper from HD and the only thing I had to do was punch a hole in the middle so the glass platen could be attached. main reason I tried this was I needed some paper with larger grit than was in stock for the Worksharp at Woodcraft. Worked fine. Less expensive, too.
    Lee Laird
    Austin TX
    Jun 2007
    4,944
    WS 3000 leather strop
    Hi,
    I made a disc from 1/2" mdf. Then I sprayed on some adhesive. And then I applied a leather disc. And then I applied some oil. And then I applied some zinc oxide. Vola! a leather strop.
    The mdf is plenty true for the (approx. 3/32" thick) leather.
    I also applied a coarser grit abrasive disc to the 1/2" mdf for the same reason; could not find source for 6" disk abrasive in the range I wanted.
    I am using more abrasive than I should because people keep coming to get their tools sharpened. It is sort of like having a swimming pool...the people keep a comin'. Maybe I should purchase disks wholesale and sell time on my WorkSharp.
    Enjoy,
    Jim
    VOTING MEMBER
  1. Inexpensive Diamond Plates for Worksharp 3000
    Last Post: 02-12-2014, 10:47 AM
  2. Worksharp 3000?
    By Ken Fitzgerald in forum New Tools
    Last Post: 05-14-2012, 12:21 AM
  3. Worksharp 3000 ordered
    By Matt Ducar in forum New Tools
    Last Post: 04-07-2012, 04:19 PM
  4. More Fun with the Worksharp 3000 - Spokeshave Jig
    Last Post: 12-07-2011, 10:39 PM
  5. Nova DVR-3000 and Nova 3000 bed extention close out
    By Stuart Ablett in forum Hot Deals
    Last Post: 12-09-2007, 02:53 AM
