Results 1 to 9 of 9
Thread: Grinding Wheel Single Point Dressing Jig
    Cotswolds, UK
    629
    __________
    __________My attempt at making a single point Wheel Dressing Jig,
    __________been in use for a while now and works fine,
    __________only reservation being that it would be better approaching from above the wheel
    __________so that grinding debris did not collect on the jig guides.
    _________ ____click on image for larger view
    __________Main requirement is for the supporting platform to be rigid so that the
    __________inevitable differences in hand pressure whilst racking the cutter do not deflect it.
    __________The Jig is firmly located & bolted as an adaptor to my normal flat grinding platform.
    Chas. just a traveller on the road of time.
    Bits & Pieces Gallery
    My Web Site
    Looks like it would work well, but S-L-O-W-L-Y
    30,014
    Very nice, Chas. It looks like it gives you very fine control over the dressing point.
    Isn't it the same basic principal Tormek dresser?
    Goodland, Kansas
    4,834
    Looks like it will work well Chas. Nicely done.
    Bernie W.
    Cotswolds, UK
    629
    Yes Vaughn, same principle, not unique to Tormek but I suppose that is the most common version seen in the hobby/craft world.
    If anything mine has a little less slack in the mechanism than the Tormek one I have used recently, downside is that it must be kept clean because of the tight clearances.
    As a matter of interest, a suggestion made on the UK forum that I fit a plastic deflector shield to the front of the cutting head to keep the debris off the guides has merit.
    My Web Site
    Jan 2008
    Stow, OH
    151
    With this "captive" system, it also true up the grinding wheel. A hand held T shape dresser may follow the wheel in and out.
    Gordon
    Chas, nice setup! Did you know ebay has single point dressers cheap.
    This way of dressing a grinding wheel is by far the best so the wheel runs true. Oneway has the same idea with the single point dresser but it's hard to use. I did get one from Bill Grumbine when he was at the club that slides on the tool rest, it works great... to good for my use. A smooth running wheel is no good for fast removal of steel
    Jan 2008
    Stow, OH
    151
    Quote Originally Posted by Doug Thompson View Post
    Doug,
    Do you mean smoothness in texture (like baby butt) or smoothness in running (vibration free)?
    I also get one from Bill at his demo. I like it much better than the Oneway. They both perform equally well, but Oneway takes more time to set up and take down than actually dressing the wheel.
    Gordon
    Quote Originally Posted by Gordon Seto View Post
    Doug,
    It's really both, after using Bill's wheel dresser the grinder ran smooth with no vibration but the wheels were no longer agressive. I need a very agressive wheel and if the tool bounces on the wheel it seams to be more agressive yet. I'll use his dresser on the 80 grit wheel for the spindle tools. Things have changed since the beginning it's all speed sharpening, well after sharpening so many I could do them with my eyes closed. Lol
  1. Grinding wheel for old Foley Belsaw Sharpall?
    By Jim Evatt in forum Old Iron
    Last Post: 01-09-2010, 12:04 AM
  2. Grinder wheel dressing tools
    Last Post: 05-27-2009, 08:52 PM
  3. A Coarse Grinding Wheel worth recommending
    By Gordon Seto in forum Turning Tool Questions and Show & Tell
    Last Post: 04-03-2008, 05:02 PM
  4. Good Quality Grinding Wheel Recommendation?
    By Bruce Page in forum General Woodworking Q&A
    Last Post: 09-24-2007, 04:45 PM
  5. cracked grinding wheel
    Last Post: 01-23-2007, 11:42 PM
