Results 1 to 10 of 19
Thread: new electroylysis tub
    11,832
    Yesterday, I rigged up a tub for rust removal with electrolysis. Made the anode from some flat steel stock I had lying around. The tub is a left over from a cattle protein feed. My battery charger completes the set-up. The hardest part was driving all over town, wasting much expensive gasoline, trying to find the Arm and Hammer washing soda. When I did find it, I'll betcha the box has been setting on the shelf for a decade, almost solid. Enneyhow, for those who have done this, how much of the soda should I use? There is probably 20 gallons of water in the tub and I tossed in about two cups of the soda. What voltage setting should I use on the charger? My choices are 2, 10 and 50. I put in a large, antique, square jawed adjustable wrench for a test at 10V and it started bubbling right away. Photo later.
    Tokiwadai, Japan
    2,882
    Frank,
    Are you sure your charger is not a 12 Volt unit with options for 2, 10 or 50 Amps?
    5,321
    ...The hardest part was driving all over town, wasting much expensive gasoline, trying to find the Arm and Hammer washing soda. When I did find it, I'll betcha the box has been setting on the shelf for a decade, almost solid. Enneyhow, for those who have done this, how much of the soda should I use? ...
    You probably have a 'lifetime' supply now, but next time you need some, go to a pool supply place. Sodium Carbonate is used to raise the Ph in swimming pools and spas. Readily available in small containers - or bulk if you need it - and relatively inexpensive.
    As for the mix, I use about a quarter cup to a gallon of water. Actual mix doesn't seem to be critical, so a bit more, or less, may work well too.
    11,832
    Quote Originally Posted by Greg Cook View Post
    Frank,
    No.
    Tokiwadai, Japan
    2,882
    No.
    Could you expand a bit on your reply? Any pics/make/model?
    11,832
    No, I wasn't sure. Me and electriks......
    You probably have it right.
    Tokiwadai, Japan
    2,882
    OK, then your 10 Amp setting should be good... I would not use the 50!
    11,832
    It's been cookin' all day on the 10 amp setting. Ain't blowed up yet.
    11,832
    photo of my fancy tub
    My electro de-rusto classy set-up.
    Winchester Ky.
    98
    Would someone mind telling how to set this processs up. I am not sure how to set it up?
