Results 1 to 5 of 5
Thread: Speaking of Digital Camera Memory.... 80% Off
    Tokiwadai, Japan
    2,882
    After Stu's thread of his search for a new digital camera, I was looking on Amazon and found this....
    http://www.amazon.com/SanDisk-Secure...6817404&sr=1-1
    Don't know how much they charge for "Shipping and Handling", but the price is great.
    Fort Washington, PA
    180
    That was another reason I got the Nikon DX40, it takes SD memory, which as Greg and others noted, is getting about as cheap as a postage stamp.
    btw... many blogs and photo users groups say that you need those high speed SD cards if you're going to take advantage of the continuous 3 frames/sec shooting in a dSLR like the Nikon. Well... I did a little experimenting. I took several SD cards I already had for other digital cameras and such, and also bought a more expensive higher speed SD card, and I set my camera on continuous mode (3 frames per second) and just held the shutter for 30 shots timing how long it took to burn those 30 shots on each card with a stopwatch. Even the cheapie no-name 1 GB SD card I got at Wallmart was plenty fast and kept up with the camera. Yes, the Sandisk Ultra II hardly slowed down at all through the entire 30 shot run, while the slowest SD card I had did slow down after an initial burst of about 10 shots, but not enough to hinder performance. It kept shooting, but a little slower, like between 1 and 2 frames per second. Heck, how many times do you need to shoot 30 strait shots at 3 fps? Again, even with the slowest SD card it only lagged behind the faster more expensive SD by a few seconds and then only after an initial burst of about 10-12 shots. My conclusion was to buy a 4GB SD card which I did, but just standard speed, which was cheaper than the "fast" 2GB card. Even at the max 10 megapixel setting, I can then shoot almost a thousand shots and not have to change out that card. 4GB cards are now as cheap as 2GB cards were at Christmas.
    Build it Break it Fix it ...repeat
    Interesting comparison, Dave. I've seen my D50 seemed to work fine with any of the SD cards I have, ranging from "slow" to "fast". I don't do much continuous shooting, and hadn't done a timed comparison, but I had a feeling the difference would be minimal.
    Maybe on a higher-end camera like a D200 it would be more apparent?
    33.8736N, 117.7627W
    435
    Maybe not. The one place I've noticed any difference is on my old (and very slow) Minolta, where the speed-up between the generic and the super-fast memory actually makes RAW mode useable. (For some low value of "useable": it's still 3-5 seconds to save each shot instead of 12-15. )
    Where are we going? And what am I doing in this handbasket?
    Rudolph, WI
    26
    One thing that you might keep in mind is to 'format' the card whenever you download all the pictures off of the card to make it more efficient.
    I really like the ScanDisk 4 gig card in my Nikon D40 and when you have to upload the pictures to your computer the Micromate USB reader works great if you don't have a card reader in your computer.
    Jim
  1. Speaking of how to use a camera
    By Chuck Thoits in forum Off Topic Discussion
    Last Post: 04-29-2013, 11:52 PM
  2. looking for a new digital camera
    Last Post: 02-10-2010, 11:32 PM
  3. Digital camera
    By Al killian in forum Off Topic Discussion
    Last Post: 09-02-2009, 11:34 AM
  4. Digital Camera
    By randy street in forum Off Topic Discussion
    Last Post: 12-24-2008, 11:54 PM
  5. Looking for a new Digital Camera - Got the new Camera!
    Last Post: 07-11-2008, 01:37 AM
