Results 1 to 4 of 4
Thread: Jointer fence question
    Catalunya
    4,632
    Here you can see my jointer/thicknesser. It is a small one but it works well enough for me specially because it is the only one I have and ever had.
    The problem is that the tilting support of the fence broke due a poor design and flimsy material. (See pics)
ID:	19019Click image for larger version.
ID:	19023Click image for larger version.
ID:	19020Click image for larger version.
    Curioulsy enough, the fence is attached to the infeed table and moves up and down with it, I do not know if this the usual way but in my ignorance it looks odd to me.
    Here goes my question:
    As the fence itself tends to flex rightway due to having only one point of attachment, I thought about drilling a couple of holes on the outfeed table and fix with screws a taller and thicker fence made out of a piece of oak that I have.
    This would allow me to exert sideways pressure when jointing an edge at 90ļ without having that flex effect.
    Obviously I will loose the possibility of planning at a certain angle,but I can buy the replacement piece and have it handy, then
    remove the wooden fence and put back the original one.
    My concern is the fact of drilling those holes on the outfeed table, they are something definitive and I'm dubious about doing them.
    Any suggestions/comments will be greatly appreciated.
    Best regards,
    Toni
    Geez Toni, that is too bad, I'd get on the tool company for a replacement part.
    If you do make your own fence to keep things at 90 to the table, I'd drill and tap holes on the infeed side, and make a notch on the fence on the out feed side.
    I think you can see what I mean in this picture.............
    The infeed is the right side.
    Good luck!!
    Catalunya
    4,632
    Hi Stu.
    Please disregard, my PM I didn't look at this post!
    Your pic shows it perfectly.
    Is there any specific reason for fixing the fence on the infeed table and not on the outfeed??
    My thinking is if it is the infeed the one that is moving downwards and the fence is fixed on the outfeed one, you do not need to make the notch, and the maximum thickness and hence resultant gap between the fence and the infeed table would be 3mm at a maximum, unless I'm making a taper on a leg's chair.
    As you see my experience with jointers is nil.
    Best regards,
    Toni
    Sep 2007
    St. Louis, MO
    583
    Toni,
    your combo machine has more than a passing resemblance to my inca.
ID:	19186Click image for larger version.
ID:	19187Click image for larger version.
    As on Stu's, the fence on mine is attached to the infeed table. Thinking about how i use mine, i usually focus on making sure the stock is flat against the fence a couple of centimeters before the stock encounters the cutter head. The Inca fence is really sturdy, but if i were in your predicament, i might either order the new part and fill the hollow back side of the casting with epoxy to strengthen it, or i would make my own - probably with a combination of wood and metal parts. For a temporary fix, i'd likely clamp a block of wood or metal to the machine.
    If you want more close up photos of the inca fence, let me know and i'll shoot some this weekend.
    good luck and let us know what you wind up doing
    Paul Hubbman
    Last edited by Paul Hubbman; 04-04-2008 at 03:09 PM. Reason: inserted incorrect photo
  1. Fence question
    By Dennis Allen in forum New Tools
    Last Post: 07-25-2012, 11:52 PM
  2. Replies: 4
    Last Post: 07-08-2011, 04:34 AM
  3. fence part question?
    By larry merlau in forum New Tools
    Last Post: 04-23-2010, 09:51 PM
  4. Another picket fence question
    By Wes Billups in forum Carpentry and Construction
    Last Post: 08-12-2007, 08:56 AM
  5. Beis fence question
    By Matt Dunlap in forum General Woodworking Q&A
    Last Post: 01-18-2007, 02:11 AM
