Results 1 to 10 of 13
Thread: Working ON My Lathe Workstation
    As most of you know, I like to fiddle with stuff, I have a streak of "Bodger" in me, as my Grandfather used to say
    I spend a lot of time at the lathe.......... OK, maybe TOO much time, but that is a topic for another thread
    The faster/easier I can get things done, the better. A LONG time ago, I worked in a steel fabrication shop, Northside Steel, in my hometown, and I had a boss there named Dan. Dan was a great boss, worked you hard, but he also taught, all the time, everyday, all day. We built a lot of things there in that factory, and most of them required lots of parts, that had to be cut, etc, often by the thousands. He taught us all how to work efficiently, using our brains instead of our backs. I have to say, this has stuck with me (thanks Dan!) so at my lathe, workstation, I've been trying hard to make the space more efficient, and easier to use.
    I moved my lathe into it's present spot a while back, and I built the one cabinet for it, but I needed some "on the wall" tool storage, and now I have some.
ID:	19049 Click image for larger version.
    I thin I have it mostly covered, and I still have space for more stuff when (not IF, but WHEN) it comes along.
ID:	19051 Click image for larger version.
    I also built an adjustable arm for my main light, this makes is MUCH more useful. I might have to add a spring or two to help the arm stay in place, or some friction pads (PSA sandpaper ) on the joints to make them slip less, but still, the light on the arm is SUCH an improvement, I have light right where I want it.
    I show this to you guys, in the hopes that someone will have a better way to do something and share that too
    11,831
    You have a way with making the mostest from the leastest, at least, space wise. Were you a submariner in a previous life?
    Jul 2007
    Des Moines, IA
    854
    Well done Stu. I like the light setup you have. Any way you could detail that for us.
    You know Frank, on a different board, a guy there asked me the same question, as he WAS a former "submariner"
    I do what I can with the space I'm blessed with
    Quote Originally Posted by Wayne Bower View Post
    Thanks Wayne, I'll take some pics later and post them, not much too it, but I'll be glad to share what I've done with you guys!
    London, Ontario, Canada
    19
    Nice setup Stuart. I like the dust collection. Is having the light that close to the work better than a couple of spotlights mounted on the ceiling? I use a similar setup now (I usually find them at garage (tag??) sales for ~$1.00). I usually get ones with clamping bases so I can clamp them anywhere. However, I find the light fixture sometimes gets in the way so I was thinking in my new shop while I'm doing the wiring I'd mount a couple of flood lights over the lathe. I'm not sure though if that would shed the best amount of light on what I'm doing.
    Regards,
    Barry
    No matter what you achieve,
    somebody helps you.
    Behind the creation
    that we call our own
    are the thoughts and efforts of many.
    - Althea Gibson
    Hi Barry
    I've got a couple of those desktop lamps, but I've really no where to mount them at this workstation, the ceiling was the only way, and as the lamp hangs upside down, the springs are pulling the wrong way!
    So I made my own
    Wayne, here you go, I upgraded it a bit, I cut round ends on it and put some springs on it, to help it stay in place.
    Here are the basic components;
    Two arms
    Top flange
    Bottom flange
    Nuts, bolts, and washers
    Not in the pic is a mounting block on the ceiling,
    which is just a block of 3/4" plywood, with a bolt sticking out of it.
    here is is all together, lying on the bench
    Mounted to the ceiling, and with springs on the top joint and the middle joint.
    I've turned it way out of position to get a pic of this bottom flange and the light.
    The middle joint, you can see the spring I put on there,
    it seems OK now, but I might have to move one of the
    screw a bit to alter the tension on the spring.
    The top joint
    You can see the spring there, I have since moved the screw at the top further around the arc of the arm by
    about an inch, to the left and down, works well.
    The springs are from a muffler on a motorcycle.
    The top joint turned.
    You can see the mounting plate on the ceiling,
    well, actually that is a beam, not the ceiling,
    but you know what I mean.
    I may yet alter it some more with some use, I think the top arm could be about 3" shorter, but time will tell.
    Easy to make, much cheaper than buying a new one!
    Goodland, Kansas
    4,834
    Great job Stu. Looks like it will work for you.
    Bernie W.
    NH
    4,005
    Looks good Stu, The only thing I would do is add about 5000 square feet to your shop
    13,443
    Lamp looks good Stu, very inspiring, need to get on with building my lathe station.
    To a small child, the perfect granddad is unafraid of big dogs and fierce storms but absolutely terrified of the word boo. Robert Brault
  1. Lathe Speed Adjustment not working
    By Dawson Mossman in forum Turning Tool Questions and Show & Tell
    Last Post: 07-23-2009, 04:57 PM
  2. Improved workstation
    By Peter Rideout in forum Shop Tours
    Last Post: 06-04-2009, 01:40 AM
  3. Music Workstation
    By Brent Dowell in forum Flatwork Project Showcase
    Last Post: 02-12-2009, 02:50 PM
  4. Music Workstation
    By Brent Dowell in forum Designs, Plans and Sketches
    Last Post: 02-02-2009, 12:18 PM
  5. My helper, now for the first time working on my lathe
    By Ad de Crom in forum Lathe Project Showcase
    Last Post: 10-26-2007, 01:53 AM
