Results 1 to 8 of 8
Thread: Board Buddies Opinions
    Cedar Park, TX
    320
    Guess it is really too late to affect my decision since I already ordered them and they are on the way. But . . .
    Over at another forum, one of the members recently posted about a kickback during a rip cut. In his case, it looks like a technique issue was the main culprit. Technique and not even a splitter, much less any other safety devices. Though I have seen ever so many posts on kickbacks, this one got to me. He was asking about feeders and such, but I went and took a good look at Board Buddies and not only linked to them in a post, but ordered a pair for myself. Fifty bucks, including shipping, seems little enough price to pay and it seems to me that in addition to the safety factor, they should add significant accuracy to rip cuts by keeping the work piece snuggly against the fence, and in the case of grooves and other non-through cuts (even on the router since I use a table saw extension router table) the downward pressure they apply should help keep a consistant depth of cut.
    Anyway, is anybody using these and, if so, has your experience with them been bad, good, indifferent?
    BTW: In the case of the kickback incident mentioned above, Board Buddies would have prevented it since it appears his technique actually pushed the board toward the blade instead of the fence at the end of the cuts. It was only a matter of time before it happened, and I most amazed that it hadn't happened previously.
    Jerry
    Carlyle IL
    350
    I like them. I only use one on the backside of the blade.
    Fort Washington, PA
    180
    Almost bit last woodworking show I was at... basically would be a time saving thing, as I have plenty of featherboards, both home made and bought already for various machines. The board buddy would in many setups be quick and easy. I also almost picked up a pair of those heavy magnetic featherboards. Talk about quick and easy, plop it down, turn the switch and instant featherboard.
    Build it Break it Fix it ...repeat
    Floydada, Tx
    1,941
    I had a pair on my ts, but I do not own one now. I do have them on my ras and really like them. I feel they are worth the money.
    Board buddies
    I've used the Ripstraight (similar technology) for years and love it.
    Jack
    San Antonio, Texas
    765
    I have them and I've been very pleased. I only use the pair on wider boards. For more narrow stock where I can't get my push block "safely" by the blade I do like Joe and only use one on the back side of the blade.
    I just have figure out how to get them mounted to my new Biese fence without drilling a bunch of holes in it.
    Billy B.
    "It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first." - Ronald Reagan
    Carlyle IL
    350
    Quote Originally Posted by Billy Burt View Post
    Those holes only hurt once.
    Cedar Park, TX
    320
    Thanks all for the replies.
    Jerry
  1. Vertical Chest Board and Chalk Board
    By Jeb Taylor in forum Flatwork Project Showcase
    Last Post: 02-25-2012, 10:56 PM
  2. Board Buddies for the table saw
    By denis gefter in forum General Woodworking Q&A
    Last Post: 04-07-2011, 05:03 PM
  3. Checker Board - Opinions Wanted
    By John Whittaker in forum Flatwork Project Showcase
    Last Post: 08-22-2007, 01:51 PM
  4. Board Buddies
    By Chris Fairbanks in forum General Woodworking Q&A
    Last Post: 01-18-2007, 02:09 AM
