Results 1 to 10 of 26
Thread: Winged Bowl in Burl
    Zushi, Japan
    739
    Winged Bowl in Burl
    Today I went into the workshop to do something completely different but instead came out with this small winged bowl. I have an end table on the block that I haven't quite started so... You may remember a platter I made back in September that had some remarkable burl figure in it. I still have a couple chunks so I made this today out of one of the chunks. The remaining chunks though are quite small. This bowl is W-120 x L-280 x H-22mm. The finish is BLO/Tung/Poly mix polished out with the Beal system.
    Al, that is really nice!
    Must have been some wind coming off of that one when you were turning it
    Zushi, Japan
    739
    Ya probably I should be saving these projects for the summer when we can all use that cool breeze.
    San Antonio, Texas
    765
    Beautiful knuckle buster, Alex! I love the color variation in that burl.
    Billy B.
    "It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first." - Ronald Reagan
    Oct 2007
    Harvey, Michigan
    687
    Beautiful work Alex! Great looking burl! I really like the elongated form and the clean detail lines to highlight the 'lip' area of the bowl! Really outstanding work Alex!
    Steve
    Jul 2007
    DSM, IA
    5,719
    Beautiful Alex! Wonderful burl in that one. Well Done.
    My Website
    Very nicely done. The wood certainly has a lot of depth to it in that top photograph. Probably wasn't that fun to sand though.
    Zushi, Japan
    739
    Thanks all for the comments.
    Quote Originally Posted by Robert McGowen View Post
    Rob the wood looks quite three dimensioal after applying a finish. Probably the most dynamic wood I have turned. Sanding wasn't that bad.
    S E Washington State
    3,777
    That is beautiful. Looks scary to turn! The smaller stuff would make some nice pens, if you are into that sort of thing.
    Fort Worth, Texas
    241
    That's top-shelf! Nice use of the rings to accent the rim.
    I may be lost but I'm making good time!
    Three Seasons Woodturnings
  1. winged bowl
    Last Post: 03-28-2012, 04:15 PM
  2. winged, lidded, bowl? box?
    By Dennis Ford in forum Lathe Project Showcase
    Last Post: 11-16-2009, 07:29 PM
  3. Winged Crotch Bowl
    Last Post: 05-17-2009, 06:06 PM
  4. Winged Bowl
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 08-13-2007, 08:06 PM
