Results 1 to 8 of 8
Thread: Making Things Round
    15,815
    Making Things Round
    With the last batch of Ginko wood cluttering up my Dungeon, I wanted to show you guys how I make my squares round, ideas, suggestions, comments welcome!
    OK, here is a little resaw sled that I built today, took about 30 minutes. Works good, but I understand it is disposable.
    Here is a chunk of not round Ginko wood to be cut into a round bowl blank.
    I've now mounted it in the sled, the two end pieces slide in a t-track, and then I use at least three good screws to hold the wood
    Ready to make my first cut
    First cut done!
    Now I've mounted it up so I can trim the bark off
    That side is now flat, so I have a flat(ish) one four sides blank, I can now make round(ish).
    Using my sharp dividers to scribe a circle in the wood
    Now Big Blue gets to nibble away at the blank making it round)ish
    There we go, signed, sealed and dated, I only have about another 20 or so to go!
    watch your fingers stu! even with screws holding the blank to your jig if the blade catches with the wood above the table it`ll slam the blank into the table .....probably won`t hurt that big ol` blade but it`ll make ya` pay attention.....tod
    15,815
    Well, that is true, but I was doing this Maloof style (FREE HAND!!) and one got away from me, and it did put "Dimple" in the blade
    The way I do it now, there is almost always a flat on the bottom, so I think it is fairly safe, but yeah, I hear you, I push on the back of the jig, and use one of them hand help push pad things on the face.
    Makes a lot of cut offs, going to the garbage stuff.
    Man I'm going to have a lot of wood to turn!
    Tokiwadai, Japan
    2,882
    Everytime I see the size of that blade on Big Blue...I am in awe..and shudder a bit thinking what cuts it makes.
    Do be careful.
    Greg
    30,230
    Quote Originally Posted by Greg Cook View Post
    Do be careful.
    Greg
    I dunno Greg, I'd think it might be the little 1/4" blades that'll lull you into a false sense of security before biting you, and they bite flesh just as hard and deep as a 2 incher. At least with Stu's blade, it's hard to miss seeing it. It is a wicked looking thing, though.
    11,900
    Some of us use lathes to make things round.
    15,815
    Some of us have lathes that work
    Check out this thread Frank...........
    Hunka Hunka Turning Love!
    Dunno if you would have tried this on your old lahte.........PS when is the new one coming?
    11,900
    New one? I wish. Put on back burner after the Dodge truck gave unexpected fits this year.
    The ginko pot looks good. We have a few ginko trees here but none are very big and are usually planted for decorative purposes so not much, if any, of the wood is available for turning.
  1. Replies: 3
    Last Post: 12-21-2011, 03:37 PM
  2. In a round-about way
    By Ken Cook in forum Jigs and Fixtures
    Last Post: 12-09-2011, 01:14 AM
  3. Don't know why I keep making these things, OCD I guess
    By Barry Richardson in forum Lathe Project Showcase
    Last Post: 12-05-2008, 05:04 AM
  4. NOT Round........
    Last Post: 11-24-2007, 02:07 PM
  5. Making things easier, or for me, automatic
    By Ken Easley in forum Site Questions and Test Posts
    Last Post: 08-14-2007, 05:33 AM
