Results 1 to 3 of 3
Thread: Cutting small &narrow pieces on table saw
    Nov 2007
    Poland
    267
    Good day
    I had to rip a few small pieces for some router table aid/fixture and I would like to share with you the method.
    I'm using an Auxiliary fence clamped to the rip fence...now, when I'm saying Aux fence.... give me some good width say, 4"~6"....you don't like to "drive" in congested areas, do you...
    Before clamping the Aux fence, give it a pass through the blade just to make sure that its parallel and consistent in width.
    The sled is made of 5/16" (8mm) "Floor panel" but of course, you can use plywood or MDF.
    It's very easy to make it, just a runner glued/screwed under the board...you don't need a fence but you can add one and use the sled as "multi purpose"...as I do...
    As you will see, I'm holding both hands on the trowel and that, doesn't leave too many hands or fingers to be used as a "Backer board" for the workpiece...saves a lot of money...(no need SS )...
    Regards
    niki
    Nov 2007
    Poland
    267
    Sep 2007
    Central (upstate) NY
    1,457
    Wow. Very impressive.
  1. Cutting angled pieces
    By John Terefenko in forum General Woodworking Q&A
    Last Post: 09-07-2012, 12:18 AM
  2. 2 small tables-end grain lamp/end table, small storage coffee table
    Last Post: 06-01-2009, 11:06 PM
  3. Jig for cutting narrow pieces
    By Ron Roase in forum Jigs and Fixtures
    Last Post: 01-04-2009, 02:24 PM
  4. Cutting very small pieces on TS
    Last Post: 02-04-2008, 02:26 PM
  5. Replies: 8
    Last Post: 12-23-2007, 06:48 AM
