Results 1 to 6 of 6
Thread: 50% off Freud HD Multi-Purpose Saw Blade
    Southern Louisiana
    947
    don't know anything about this blade but sounds like a good price.
    http://www.ptreeusa.com/edirect_040408.htm
    Odessa, Tx
    1,813
    I sure wish someone would sound off about this blade if they have ANY experience with it. I would mostly be interested in how it cuts and holds up cutting MDF and Melamine products, (and other material too of course), but I would like to have an "Economically Priced" blade for a number of anticipated projects, (shop related) that will use a good amount of MDF. If they are real good blades, I might need two.
    Rochester
    846
    Quote Originally Posted by Norman Hitt View Post
    Hi Norman - MDF and melamine are exactly where this blade's strengths are. For hardwood and plywood use, I'm not real impressed with it for my uses...it's bogs more than some, doesn't cut as cleanly as others, but the triple chip grind should hold up well in MDF, laminates, and melamine.
    Got Wood?
    Odessa, Tx
    1,813
    Quote Originally Posted by scott spencer View Post
    Hi Scott, thanks for the reply, as that's just the information I needed. I finally remembered and found your old post about the sawblades and from your chart and explanation there I suspected it would do what I need it to do, so........now to get one ordered.
    Thanks again.
    Annnnnd......before I forget it, Thanks Chris for the heads up on this, (I ordered two after all).
    37° 5'16.25"N 76°25'28.11"W
    193
    Norm,
    for Melamine you'd be happier with a LU80R010. It's a bit more expensive, but the cut quality is far better in both Melamine and plywood. I have both blades and I can tell you the LU80R010 With a ZCI has less chip out in both ply and Melamine. It's a great blade for crosscuts also. You just can't expect a general duty blade to perform as well as a dedicated purpose blade.
    Mike
    Take a look at what Freud says about each:
    LU82M010
    LU80R010
    Odessa, Tx
    1,813
    [QUOTE=M Toupin;97303]Norm,
    Thanks for the additional info Mike. It's too late now since I already ordered two of them, but for what I have in mind for them, they should do ok, 'cause a little chipping won't really matter, (and they fit my current budget) I have a Freud ripping blade that cuts it smooth as glass if I really need to use it, but for a lot of cuts I would like to "Save" the more expensive blades when looks won't matter.
  1. Freud Blade, best deal
    Last Post: 01-24-2012, 05:14 PM
  2. Replies: 2
    Last Post: 01-14-2010, 05:05 PM
  3. 10" Delta 35-7657 40T General Purpose Blade - $17
    By scott spencer in forum Hot Deals
    Last Post: 10-14-2009, 07:41 AM
  4. new Freud blade set
    By Mark Kosmowski in forum New Tools
    Last Post: 01-24-2009, 02:50 AM
  5. Thoughts on Freud’s Fusion Hi-ATB 10” Blade?
    By Bruce Page in forum General Woodworking Q&A
    Last Post: 09-04-2007, 10:49 PM
