Results 1 to 7 of 7
Thread: faceplate question
    North Carolina Foothills
    56
    faceplate question
    Any recommendations on type of screws to use for faceplate turning?
    Square drive (Robertson) sheet metal screws are about the best, I would think.
    If you want more holding power, then go with hex drive, lag bolts, but be sure to pre-drill for those.
    NEVER use drywall screws, they are very hard, and thus brittle, they WILL break, which WILL wreak your day.
    My latest favorite are relatively thin (#10 or #8, I don't remember offhand) hex head lag bolts, about 1 1/2" long. I drive them with my 14.4v impact driver and no pilot holes. (Green wood only. For dry wood I'd be drilling the holes.) Prior to that, I was using #10 or #8 pan head Phillips head sheet metal screws, also about 1 1/2" long. Robertson head sheet metals screw (as Stu mentioned) would also be good.
    Mason Michigan
    455
    Spax
    http://www.spax.com/usa/
    I learned about them in Bill Grumbine's video.
    "Small Change got rained on with his own 38"
    Tom Waits
    I have always used shanked Flathead Steel Wood screws. Reason is because the shank adds more shear resistance, But of late I have converted to Sheet metal screws (flathead) because woodscrews are getting harder to find and proper sized Sheet metal screws have enough mass to resist shear. Never less than a #10 or #12 screw. You need flathead screws to draw the faceplate snug and prevent any lateral movement.
    Sorry Vaughn.... Always predrill pilot holes (even in green wood) driving screws into wood w/o pilot holes only starts the splitting process and has half the gripping strength (estimate w/o scientific study) as it opens/seperates the fiber structure to allow penetration of the screw similar to a nail, Remember that a screw is a coiled wedge and as such it pushes apart the fibers. Pilot holes allow for the threads to cut through individual fibers and create a secure holding surface.
    Seldom use the same screw repeatedly as each time it is used metal fatique becomes more taxing and weakens the screw.
    Goodland, Kansas
    4,834
    I use stainless steel hex head screws that are self drilling. Kinda pricey but they hold well and green wood doesn't bother them.
    Bernie W.
    NEVER use drywall screws, they are very hard, and thus brittle, they WILL break, which WILL wreak your day.!
    Very Wise Words ...
    Repeat this as many times as necessary to imbed it in your mind before you imbed a turning in your skull.
  1. Buying a new lathe faceplate
    By Tom Baugues in forum General Woodturning Q&A
    Last Post: 09-19-2014, 10:55 PM
  2. Faceplate Mounting on an Uneven Surface
    By Vaughn McMillan in forum General Woodturning Q&A
    Last Post: 02-21-2013, 05:10 AM
  3. faceplate ?
    Last Post: 09-18-2008, 09:23 PM
  4. Another faceplate question
    By gary doby in forum General Woodturning Q&A
    Last Post: 04-22-2008, 01:23 AM
