Results 1 to 10 of 22
Thread: Pen Drilling Ideas
    Apr 2008
    Columbia, SC
    22
    Pen Drilling Ideas
    Ok so I dont wanna buy a pen drilling jig, those things run about fifty bucks, but after trying to drill them myself and ruining several nice pen blanks I need some help, what do you guys suggest when trying to drill the pen blank for the insertion of the brass tube!
    Thanks
    Red Deer, Alberta, Canada
    618
    If you're using a drill press you could just put the blank in a handscrew like the ones shown here:
    Just be sure the blank is plumb to the drill bit and you should be good to go.
    Cotswolds, UK
    629
    I just hold mine in a hand clamp.
    http://quest42.co.uk/woodwork/pens/pens.htm
    Chas. just a traveller on the road of time.
    Bits & Pieces Gallery
    My Web Site
    30,017
    I just use a cheap little drill press vise similar to this one:
    I put a thin piece of wood underneath the bottom end of the blank so I'm not drilling into the gap in the middle or the cast iron vise on either side...it also helps prevent blowout. I don't usually anchor the vise - I just position it by eye and hold it by hand. I do use a drill press. I don't think I'm good enough with a hand-held drill to do it without a press.
    Drums, PA
    292
    I drill on the lathe using a scroll chuck to hold the blank and a drill chuck in the tailstock.
    S E Washington State
    3,777
    I use either of these, both are simple and work fine. the one on the right I built from watching Bill Baumbeck's Basic Pen Turning video.
    lutefisk capitol, USA
    485
    I had one from Rockler that was about $12 and made to attach to their drill press fence. Since I didn't have the table and fence at the time I used a pocket hole setup and screwed it down to a piece of 3/4 plywood.
    Here is what I did..........
    >> Pen Drilling Vice <<
    ....I've made a lot of pens and this thing just works great, quick and easy too!
    While I'm at it, look at my >> Pen Press << too
    Goodland, Kansas
    4,834
    I use the same thing as Vaughn. I use a machinist square to make sure it is straight up and down. Works great.
    Bernie W.
    Pen drilling ideas
    does any one have the Rockler pendrill/press combo that sells for $90.00?
  1. Lathe Drilling Jig ?
    Last Post: 02-19-2014, 05:58 PM
  2. Pen Drilling Jig
    By Raymond Sprouse in forum Jigs and Fixtures
    Last Post: 05-26-2011, 10:25 AM
  3. Drilling a lamp
    By Dennis Kranz in forum Turning Tool Questions and Show & Tell
    Last Post: 07-01-2010, 03:53 PM
  4. drilling steel
    Last Post: 05-30-2008, 01:26 PM
  5. Lee Valley Drilling Kit
    By Rob Bodenschatz in forum General Woodworking Q&A
    Last Post: 11-30-2007, 09:09 PM
