Results 1 to 10 of 10
Thread: Faceplates
    Vernon, WI
    230
    Faceplates
    Looking at a bunch of your guys' pics on here and your pages, I've noticed some of you have some smaller faceplates (about 2inch) that have like 8 screw holes. I was just wondering if anyone knew where I could order faceplates that size?
    11,833
    Try Craft Supplies a/k/a CS http://www.woodturnerscatalog.com/cg...?page_number=1
    Order their catalog, known as the Woodturners Catalog. This is one of the most popular sources for many woodturning/carving items and projects.
    lutefisk capitol, USA
    485
    Rockler also carries some smaller ones. They are aluminum and I believe made by Don Pencil. Either place will treat you right.
    Jan 2008
    Stow, OH
    151
    I rarely use faceplates any more. I like to use face plate rings like this:
    http://www.teknatool.com/products/Ch.../Faceplate.htm
    With faceplate ring, I can reverse turn without removing the faceplate immediately. I can still use the tailstock for support. I can flip the blank back and forth to refine the shape without any run out problem. As a bonus, I can leave the chuck on the lathe all the time. Sometimes flipping the blank gives you easier access.
    Gordon
    Los Angeles, CA
    2,668
    You can buy them directly from Don.
    http://donpencil.com/
    Quote Originally Posted by Mohammad Madha View Post
    And don't forget to check the "Seconds and Blems" link at the top of the page. That's where I've gotten all my faceplates, plus my Stinger hollowing bars. (I use them on the Monster rig for smaller stuff.)
    Quote Originally Posted by Gordon Seto View Post
    Gordon,
    Would you recommend this for large projects (say a 16" X 8" bowl)?
    Kurt
    Jan 2008
    Stow, OH
    151
    Kurt,
    I really have no idea. I enjoy turning in smaller scale.
    I normally use the smallest of the 3. It is adequate for even off-center turning. The lathe vibrates before the ring comes loose.
    The picture is the large ring which I have never used. The OW live center was for scale. The external diameter is 6.25". The ring is made out of steel; I assume you can drill extra holes for additional screws for security
    Gordon
    Thanks Gordon,
    I hadn't noticed the big one. At 6+" across, it must be intended for pretty large stuff.
    Cheers,
    Kurt
    Vernon, WI
    230
    Thanks for the links everyone! Definitely what I'm looking for. Gordon, that is a pretty cool idea I might check into that also.
  1. Free Faceplates!!
    Last Post: 12-30-2007, 05:46 PM
