Results 1 to 3 of 3
Thread: FS: Porter Cable 7556 1/2" Right-Angle Drill Kit
    Fredericksburg, VA
    161
    This is a beast of a drill!!! It has seen very light use, and is very well taken care of. Here is a full list of specs...
    Includes Drill, Right angle drill attachment #5079, Side handle #810820, Chuck key #875134, Carrying case, Operating manual.
    Features:
    8 Amp, AC only
    Three speed choices; 0-500 RPM straight line drilling 0-330 RPM or 0-750 RPM with right angle head
    Variable speed, reversing
    Capacities: 4-5/8" wood, 1/2" steel
    Extra-heavy-duty 3-stage gearing
    100% ball & needle bearings
    Cast aluminum machined gear housing & bearing plate
    Side handle mounts right or left on drill housing or right angle head
    Dust sealed switch
    Standard Equipment: Drill, right angle drill attachment #5079, side handle #810820, chuck key #875134, carrying case, and operating manual
    Specifications:
    Power: 120 VAC, 50-60 HZ
    Length (Inches): 18
    Net Weight: 11 Lbs.
    Motor Amps: 8.0
    Motor Watts: 920
    Chuck Size: 1/2
    Gear Reduction: 3-Stage
    Drilling Capacity (Inches) - Speed (RPM): LO 0-330, HI 0-750
    Drilling Capacity (Inches) - RT Angle Length (Inches): 6
    Drilling Capacity (Inches) - Wood: 4-5/8
    Drilling Capacity (Inches) - Steel: 1/2
    I am asking $200 for this drill. I will ship, but buyer pays actual shipping charges.
    Attached Thumbnails Attached Thumbnails PC7556_1 (816 x 612) (800 x 600).jpg
    "Listen, here's the thing. If you can't spot the sucker in the first half hour at the table, then you ARE the sucker. "
    Fredericksburg, VA
    161
    The reduced price for this drill is $180.00.
    - Keith
    Fredericksburg, VA
    161
    Another UPDATE!!!
    Price adjustment......AGAIN!!!
    Now on sale for an astounding $110.00!!!!
    C'mon, folks.....work with me here....
    - Keith
  1. Is this Bandsaw Any Good? 14" Porter Cable at Lowes
    By Mike Turner in forum New Tools
    Last Post: 12-08-2012, 10:27 PM
  2. New Porter Cable 8" Variable Speed Grinder
    By Rich Aldrich in forum Turning Tool Questions and Show & Tell
    Last Post: 05-12-2010, 09:56 PM
  3. Porter-Cable 352VS 3"x21" Belt Sander
    By Rob Bodenschatz in forum Old Ads
    Last Post: 02-21-2010, 07:32 PM
  4. Porter Cable combo kit
    By Al killian in forum New Tools
    Last Post: 02-05-2008, 03:52 AM
  5. Replies: 0
    Last Post: 11-29-2006, 08:59 PM
