Results 1 to 7 of 7
Thread: Creating A Three-Cornered Miter
    Fredericksburg, VA
    161
    My son asked me to make him a display case for one of his soccer balls. He wants it to be a five-sided, glass cube, with a base to sit on. I've seen examples of how people bring three sticks together at a corner, like the attachment below, but I can't for the life of me remember how it's done.
    Any tips or suggestions would be greatly appreciated!!!
    - Keith
    "Listen, here's the thing. If you can't spot the sucker in the first half hour at the table, then you ARE the sucker. "
    Floydada, Tx
    1,941
    I think wood magazine has a article on how to make it. If I remember I will look when I am down in the shop.
    5,320
    Four sided is easy. Cut a 45 on the end of each piece, then roll each peice 90 on the saw's table and cut another 45. This gives you three pointed sticks. Assemble carefully, and you've got it.
    I'm not sure how it'd be done for a pentagon, but I think you'd cut one angle on two peices at 36, and the other angle at 45. The third (bottom) piece would be two 45 cuts.
    May 2007 issue of Wood Mag, or http://woodstore.net/thmijo.html
    Odessa, Tx
    1,813
    When in doubt, draw it out, (to scale) and measure the angles.
    SE London
    11
    IIRC Rick Chistopherson (sp?) on the FOG site is very good at this sort of maths - and explaining it.
    Regards
    ...Such stuff as dreams are made on.
    Between St Joseph and Savannah, MO
    147
    Do you mean like this?
    I have a short write-up on my blog. It will require some patience, but if I can do it, you will too! Take your time, and sneak up on the final fit.
    Al
    Watch videos from Woodworking in America in Berea, KY
    New blog URL: http://sandal-woodsblog.com/
    Sandal Woods - Fine Woodworking
    We will build your heirlooms
  1. Creating and cutting with a template
    By Shawn Anderson in forum General Woodworking Q&A
    Last Post: 06-21-2014, 12:07 PM
  2. miter saw
    By ken lutes in forum Classified Ads
    Last Post: 08-15-2012, 01:05 AM
  3. Creating a template
    By Chris Hatfield in forum General Woodworking Q&A
    Last Post: 01-24-2011, 12:13 PM
  4. My new miter saw
    Last Post: 06-13-2009, 11:26 PM
  5. Which Miter saw to buy? Need help.
    By Barry Allweiss in forum General Woodworking Q&A
    Last Post: 08-21-2007, 04:15 AM
