Results 1 to 10 of 16
Thread: it's Griz's fault (and Ned's!)
    Sep 2007
    Central (upstate) NY
    1,457
    I'm going to try to place an order for (among other things) a Hock blade for the plane Griz helped me restore and I want to know what the protective stuff is that I want to get for it (Carnuba oil?) so I can see if craftsmanstudio carries it.
    Thanks!
    Sacramento, CA
    1,367
    Camelia oil, perhaps?
    Jason Beam
    Sacramento, CA
    Sep 2007
    1,457
    Quote Originally Posted by Jason Beam View Post
    Yes, I think that is the stuff. For whatever reason I always confuse it with carnuba wax, but at least I know carnuba wax is wrong.
    Thanks!
    5,533
    hey for once it isn't My fault!! Woohoo!!
    -Ned
    oswego county , upstate n.y.
    280
    Quote Originally Posted by Ned Bulken View Post
    ned its always your fault !!!!!!
    and yeah mark you've got it now camilla (sp) oil . you only need a small bottle , it will last for years to come
    what are you building today ??
    GRIZZLY
    5,533
    Quote Originally Posted by jim capozzi View Post
    Now waitaminute, how is this My fault? Oh, yeah, you guys wouldnt' have met if it weren't for my shop...
    ok, my 'bad' I guess.
    -Ned
    Sep 2007
    1,457
    After this whole thing I ended up not getting the Camellia oil.
    I did get a Hock replacement blade for my restored Craftsman plane (it looked to be closer to 1 3/4" than any other choices, so that's what I ordered), a Beall angle measuring tilt box and a height gauge adapter for the combination square. This brought me just over the required purchase amount for free shipping from Hartville Tool - they don't offer Camellia Oil on their website.
    Now comes the hard part - waiting for the new toys to get here!
    280
    hi mark
    can't wait to see pics .....you know the drill by now
    the only places i have seen camelia oil is lie-nielsen and mayyyyybe woodcraft ? i got mine from the lie-nielsen website i think
    GRIZZLY
    5,176
    camellia oil & applicator
Name:	Camellia Oil & applicator.jpg
    I learned this from Frank Klauz some years ago.
    Camellia oil is good to help keep metal clean and shiny. The applicator is a piece of 2" PVC with end caps. The material inside is a felt block cut to fit. Chalk board erasers work real well for this. Remove the "board" top from the eraser and just use the felt.
    A friend used an old tee shirt cut into strips and rolled as tight as he could get it and stuffed it in. Then he barbered the edges for a nicely shaped applicator. Lots of ways to skin this cat. The idea is to get the applicator material jammed into the PVC as tight as possible.
    The bottom cap is flat on the end. The top cap is slightly domed. It is easy to tell the top from the bottom. The bottom is glued on. This was serendipitous. Just happened to find two different styles in the borg bin.
    Cut the PVC to allow your applicator stand proud by a 1/2" or so. Mine is about 2-1/2" long.
    Once the applicator is completed, simply add camellia oil until the applicator is saturated.
    The size works well on everything from hand planes to jackknives.
    Sep 2007
    1,457
    Carol has it spelled the way they do at craftsmanstudio (you know what to do with the 3 double-ewe's and the com). I'll have to take a peek at the LN site though, might just use getting the Camellia oil as an excuse for a non-LA ground blade for that 62 that you were drooling over when I stopped by!
    That was a good applicator idea - thanks!
    Oh, just saw in the email inbox that the Hock blade order is shipped and the UPS site says it is en route!
  1. Putting the new Griz 766 through it's paces
    By hu lowery in forum Lathe Project Showcase
    Last Post: 10-16-2015, 01:24 PM
  2. Ready to order new Griz jointer-coupons?
    By Jerry Ingraham in forum New Tools
    Last Post: 12-29-2011, 06:29 PM
  3. This is truly sad, regardless of fault
    By Julio Navarro in forum Off Topic Discussion
    Last Post: 04-14-2011, 02:00 AM
  4. Griz and P-tree Black Friday Ads
    Last Post: 12-08-2008, 06:57 PM
  5. My new Griz progress report
    Last Post: 01-24-2008, 08:05 PM
