Results 1 to 10 of 13
Thread: Hollow Form........ WIP
    Dunno if this one will survive the ride or not, but it has so far........ with some help from Mr. CA Glue that is
    In >> this thread <<, I show how I processed some large chunks of wood I have, on the largest piece, there was this "Bump" that I cut off, and it looked to have some interesting figure in it, but it also had a bad inclusion/void in it......
    You can see it here
    Well, it DOES have some nice figure and burl in it, but man did it want to fly apart at times.
    I took it down to nearly an 1/8" except the bottom, which I left a full 1/4", and it is still a bit green, too green to sand, I tried, so I'll DNA soak it, and then, once dry, I'll sand it.
    This is how it looks now....
ID:	19312 Click image for larger version.
ID:	19313 Click image for larger version.
ID:	19314 Click image for larger version.
    The big hole in the side sure made emptying the shavings out of this hollow form easy
    Cornwall, England
    392
    Hopefully it won't crack up as you've done well to get it this far by the look of it. Be interested to see what shape it is when it is fully dry. Not much room to play with though at that thickness.
    Pete
    Did it help for monitoring the wall thickness as you were turning?
    (Nice job!)
    Kurt
    Oct 2007
    Harvey, Michigan
    687
    Now that's impressive! Love the form! Should make for one very interesting hollow form once it dries and is finished! Nice work Stu!
    Steve
    Nice, Stu.
    I think that huge void would have scared me off. I hope it survives. I can't wait to see her finished.
    George
    Thanks gents!
    I really did not think it would survive, so I went at it with a "This Will Be Good Practice" mentality, and guess what, it has survived so far....
    I know it will not have any room for re-turning, so all I hope to do is some sanding, when it is dry.
    Red Deer, Alberta, Canada
    618
    Very nice, Stu. Like the form a lot!
    Goodland, Kansas
    4,834
    Great job Stu. How was the pucker factor? It would have been high for me.
    Bernie W.
    Zushi, Japan
    739
    Looks very cool Stu. Reminds me of a Grecian antiquity. Don't know if you'd want to but maybe you could enhance that look with the finish.
    30,008
    Looks nice so far, Stu. Congrats on getting it to stay together. One problem I've seen with big voids on the side like that is that it makes it hard to sand with the piece spinning (which equals hand sanding), yet it makes it easy to see how well or poorly the inside is sanded.
  1. first hollow form
    By Clark O'Neill in forum Lathe Project Showcase
    Last Post: 04-14-2008, 02:08 AM
  2. How long does it take to hollow out a small hollow form?
    By Mike Hirsch in forum Turning Tool Questions and Show & Tell
    Last Post: 04-04-2008, 07:47 PM
  3. Box? Not exactly. Hollow Form? Well, no....
    By Kerry Burton in forum Lathe Project Showcase
    Last Post: 05-12-2007, 10:28 AM
  4. The Next Hollow Form!!
    Last Post: 05-01-2007, 02:34 AM
  5. Hollow Form
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 04-30-2007, 10:34 PM
