Results 1 to 3 of 3
Thread: Storage Ideas for a Snowblower?
    Western, NY
    41
    Question Storage Ideas for a Snowblower?
    I am wondering if anyone has figured out a good way to store a snowblower. I have an Orange Ariens 24" snowblower that is so long, tall and heavy that I can't find an out of the way place to put it... It takes up about as much space as a good sized workbench
    Mike
    810
    Drain the fuel and run it dry. While it's hot, drain the oil, pull the spark plug and squirt a bit of oil in the cylinder. Roll it over a couple of times, then put the plug back in, but leave the wire off. Tag the plug wire with a tag saying "no oil in motor". Find a corner to store it in, then stand it on its nose. It will take way less space and there'll be no fuel to go stale. Next fall all you do is add oil and fuel and put the plug wire back on.
    If you really need to have it stored outside, put it up on a pallet and cover it with a tarp, but don't tie it down so tight that it can't breathe. All it needs is to be covered enough that precipitation runs off.
    new york city burbs
    10,188
    I just finished my snowblower project, and added the proper signage.
    (its not really a doghouse.)
  1. Need Ideas - Chuck Storage - My Solution
    By Paul Douglass in forum Jigs and Fixtures
    Last Post: 04-27-2017, 09:04 PM
  2. Fire wood storage rack ideas ?
    By Paul Alford in forum General Woodworking Q&A
    Last Post: 01-12-2011, 06:03 PM
  3. Need plans/ideas for an outdoor storage bin.
    By Erin Reichelt in forum Designs, Plans and Sketches
    Last Post: 10-07-2009, 02:32 AM
  4. Watertight Storage Box Ideas
    By Keith Starosta in forum General Woodworking Q&A
    Last Post: 06-10-2008, 01:12 PM
  5. Wood racks/storage ideas wanted
    Last Post: 10-06-2007, 09:53 PM
