Results 1 to 10 of 11
Thread: Mixing Shellac
    Kansas
    409
    Mixing Shellac
    I was told to use 1 oz shellac and 8 oz of denatured alcohol. I assume the 1 oz shellac is a dry measurement (weight) and the 8 oz is a liquid measurement.
    Is all I do is put it in a jar with a lid on it for 24 hours until it dissolves?
    Thanks
    Rise above the rest
    4,992
    yup......even i can do it
    Cockeysville, Md.
    17
    Aaron,
    1 oz (dry flakes) shellac and 8oz (liquid) of alcohol will yield a 1 pound cut of shellac, a relativly thin finish but fine if you're doing several coats. I kinda like a 2 pound cut (2oz flakes and 8oz DNA).
    Sometimes it take more than 24 hours (occasionaly less) for the flakes to disolve depending on the quality and age of the flakes. Give it a good shake from time to time to help it along.
    Are you using this as a base coat for another finish or as the final finish itself?
    Brian
    ........not all those that wander are lost
    Kansas
    409
    Brian, I am using this as a base coat. I have some red oak carvings and I am going to use the 1lb cut to fill in some of the pores so it wont soak up so much stain and match more closely to the smooth sanded surface its going on.
    Rise above the rest
    Cockeysville, Md.
    17
    In general, shallac used for a base coat should be the De-Waxed type. If your's isn't, when you mix your ingredents and let it sit, the wax will float to the top and can be pored off before use.
    Brian
    Zushi, Japan
    739
    Quote Originally Posted by Brian Hale View Post
    Brian
    I have read that putting the disolved mix in the fridge will help solidify the wax and make it easier to pour off the dewaxed shellac. I haven't tried this so any comments are welcome.
    Kansas
    409
    Brian
    Mine is dewaxed, so I should be go to go.
    Rise above the rest
    Waterford, MI
    773
    I've never tried this but I've heard of folks running the flakes through an old style hand coffee grinder before mixing to help make everything dissolve. I've done a lo-tech alternative of putting them in a heavy freezer bag then pounding to break them down. I think it helps as I've noticed less undissolved stuff at the bottom of the jar since I started doing this.
    8,436
    Arron go I'd go with the thin (1 lb. cut) that you have and if you feel the need put on a second coat then it wont be a problem. The shellac will dry in about an hour and subsequent coats will melt into any under coats.
    Houston, TX
    363
    Quote Originally Posted by Doug Shepard View Post
    To add to what Doug said, you can take an electric coffee bean grinder and grind the flakes to a fine powder before you mix it with the alcohol. Shake the mix well, let it sit a while (maybe a half hour) shake it again, let sit, strain and use. really cuts down on the waiting and very little is undissolved.
  1. mixing oils failure?
    By allen levine in forum Finishing School
    Last Post: 09-05-2014, 07:41 PM
  2. mixing polyurethan with stain/color?
    By Julio Navarro in forum Finishing School
    Last Post: 12-18-2011, 11:27 AM
  3. Mixing a wipe on Shellac finish
    By Dominic Greco in forum Finishing School
    Last Post: 10-21-2009, 02:26 PM
  4. Shellac mixing ????????????
    By jim capozzi in forum Finishing School
    Last Post: 09-11-2008, 02:31 PM
  5. Birdseye Maple Mixing Bowl
    Last Post: 12-09-2007, 05:21 AM
