Results 1 to 10 of 10
Thread: even MMs ain't perfect.
    11,831
    Went to a friend's shop yesterday, partly to see his new Min-Max 16" bandsaw. It sure looks like a real workin' hoss and well made. Not the first I've seen. Saw Tod's but his is a giant professional job. This one brought a unique complaint from the owner. The miter gauge slot is cut a non-standard size and is too deep. Miter gauge can't be slid in from the end without raising and once set in the slide sets at an angle because of the extra depth. I suggested he put a piece of UHMW tape on the bottom to even things up and help it slide easier. Seems like MM would not overlook something as basic as this.
    Mebbe they need to take lessons from Grizzly. Uh-Oh. Now, I'm in trouble.
    5,320
    Was it an MM miter guage, or one from another tool? Perhaps MM has their own, proprietary guage bar - like Sears used to.
    Every company can make mistakes.......Even the great Grizzley...or Mini-Max.....or Laguna....or Agazzani.............Delta.........and the others. It happens.
    Jim...I suspect it's the one that ships with the machine. Now I'll go check mine.
    Ken
    Yorktown, Virginia
    5,014
    When I got my Laguna I was expecting to be able to use the gauge from my table saw...no such luck...the slot didn't match. You would think these things would be standardized.
    11,831
    Came with it.
    11,831
    Yep, sumptin' like spindle size and threads on lathes are standardized.
    2,784
    I bet it is standardized...to european standards. That's one of the beefs with the MM E16 like I have. But the slot is too shallow (about 3/16") for an aftermarket miter guage. Didn't bother me that much, as I don't see using a miter guage on the BS anyway. And if I find a need to, I have the factory one to use.
    But, it could be the top was just cut wrong and no one caught it. Hopefully Ken and some of the others with the MM16 will shout back witht their findings. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    Frank....tell your friend to check to make he's using the right one. I checked mine and it's perfect fit. I will check later to see if it is the same size as my table saw but the one that came with my MM-16 is accurately tight fit.
    Ken
    Waterford, MI
    773
    I'm using an Incra V27 on mine and haven't noticed any problems. I buried the crummy factory one in a drawer.
    Brentwood, TN
    294
    Frank, the MM vs Laguna quality issue is legendary. On the other hand, after you sink several thousand into any tool you feel a need to defend that call. Like the big Marine said, they all are made by humans (well, Griz may be an exception) and they reflect our humanity, complete with minor flaws. MM seems to be a good company regarding making things right.
    Member; Society of American Period Furniture Makers
  1. Not Perfect, But Here Ya Go...
    By Vaughn McMillan in forum All Things Musical
    Last Post: 12-02-2015, 02:00 AM
  2. Perfect Fit
    Last Post: 12-07-2012, 04:13 PM
  3. Perfect Fit
    Last Post: 01-17-2010, 03:29 PM
  4. A perfect day
    By John Bartley in forum Off Topic Discussion
    Last Post: 05-19-2009, 10:42 AM
  5. not perfect but!
    Last Post: 03-22-2009, 12:07 AM
