Results 1 to 4 of 4
Thread: Table saw sled - part I
    Nov 2007
    Poland
    267
    Good day
    I have only one sled that is dedicated to frame cutting at 45 and because it cuts so perfect, I don’t want to remove the triangle and use it also for normal crosscutting.
    Actually, I have two “half sleds” and sliding table so I don’t need a sled for crosscutting.
    I made this sled with small pieces ripping and crosscutting in mind.
    As you’ll see my TS is not “normal” and I have only one narrow miter slot so I had to make an “Outer runner” that runs on the table edge.
    The benefit of such a method is that first, the runner in the miter slot does not have to “fit snugly” and second, if the sled runners gets loose (play), I can always “re-tight” (or loosen, in case of humidity changes effect) or even change the “outer runner” to a new one without effecting the “Squareness” of the sled.
    Because the subject is very long…I mean, many pics (above 150), I divided it to 4 or 5 parts that I’ll post it in a few different threads.
    So, lets start….building the sled…
    Regards
    niki
    17,471
    Thumbs up thanks for another lesson
    well niki its good to see your back in action again been using your new tool to much and havnt had time to get on huh do you do projects on request like the DJ's do? we pick the question and you solve it? now there's an idea we come up with troubles and niki takes care of them for everybody on here thanks again for your efforts in the forum.
    Southeast Pa
    2,019
    Another nice Jig Niki!
    I need to make some of those triangles they look handier than a pocket on a shirt...
    Garry
    Nov 2007
    Poland
    267
    Thank you so much
    Larry
    Well yes, I was "discovering" the MultiMaster but I found some free time to make this sled that was long time in my head....just that I have to hurry because my wife have some "projects" that are not so much of woodworking
    Garry
    Yes, the triangles are very handy around the shop and just in case that you look for them....you can find them here
    http://familywoodworking.org/forums/...ead.php?t=7631
    http://familywoodworking.org/forums/...ead.php?t=7756
    Regards
    niki
  1. Table saw sled - part V
    Last Post: 04-22-2008, 05:28 PM
  2. TAble saw sled - part VI - last...
    Last Post: 04-18-2008, 08:33 PM
  3. Table saw sled - part IV
    Last Post: 04-17-2008, 03:35 PM
  4. Table saw sled - part III
    Last Post: 04-17-2008, 08:37 AM
  5. Table saw sled - part II
    Last Post: 04-16-2008, 07:34 PM
