Results 1 to 8 of 8
Thread: CA glue & Face plates
    5,533
    I'm watching the turning 101 episode about turning 101, in it David uses CA glue to attatch the waste block for the face plate to his blank. I was surprised to see that it held a 9" blank on his Oliver. Things to look forward to, though I'm saving for a barracuda in the 'near' future.
    -Ned
    11,831
    You can also try ordinary hot glue. But must use an aluminum faceplate. Once on, can't be removed with an act of Congress.
    5,533
    I expect I'll go straight to using a chuck in the end. Seems so much more convenient, and I can get a tommy-bar style one for what, $50?
    -Ned
    Drums, PA
    292
    Quote Originally Posted by Ned Bulken View Post
    I've CA glued waste blocks to 16" bowl blanks and then proceeded to core out the centers. I haven't had one break yet.
    I know Bill Gumbine uses hot glue that he melts in a shallow plate that he heats on a hot plate (If you are reading this Bill, Congratulation Grampa)
    5,533
    guess the 9" or so maximum blanks that will fit on my Midi will be fine then. Hmmm. something to think about. Kewl, thanks!
    -Ned
    Grand Rapids, MI
    383
    Warning!!
    I have heard from several turners that the barracuda chuck is not what they expected. They were very disappointed. You might want to start a new post polling barracuda owners just to make sure it's really what you want.
    Hutch
    Drums, PA
    292
    One thing I should have mentioned, the two mating surfaces must be perfectly flat.
    5,533
    Quote Originally Posted by Matt Hutchinson View Post
    Hutch
    Hutch,
    thanks for the tip. I am fortunate enough to have access to a barracuda to test drive. Mark k has the same model lathe as I do, and he already has a Barracuda in his shop. Neither of us have used it as yet (that I know of at least), but the shop is open now, so it will only be a matter of time.
    I'll post results and thoughts on it once we start turning in earnest.
    -Ned
  2. Name Plates
    By Marshall Border in forum Flatwork Project Showcase
    Last Post: 01-02-2011, 05:35 AM
  3. Offering Plates in Oak
    By Ted Calver in forum Lathe Project Showcase
    Last Post: 11-18-2010, 01:48 AM
  4. Coaster Plates
    By Stuart Ablett in forum Handtool Project Showcase
    Last Post: 05-09-2010, 06:40 PM
  5. Face to Face Glue-ups Without Sliding
    Last Post: 11-04-2009, 05:45 PM
