Results 1 to 10 of 19
Thread: Episode II: Doorlink strikes back!
    Inside the Beltway
    2,666
    Well, folks,
    You knew it would happen after the whole festool thing: Doorlink wants results! Not directly from the saw, but indirectly on her projects. It's downstairs bathroom time. Ouch!
Name:	bathroom 001 (Medium).jpg
Name:	bathroom 002 (Medium).jpg
Name:	bathroom 003 (Medium).jpg
Name:	bathroom 004 (Medium).jpg
Name:	bathroom 005 (Medium).jpg
    The whole story coming soon...
    Bill
    5,172
    Oh, good! You finally got the floor part on the bottom.
    No wonder she wanted you to get going on that project!
    Must have been real hard to use, laying its side like that.
    Cedar Park, TX
    320
    The Lord knows that I am not, by any means, Mr. Deco, but I don't blame her a nit for wanting something done about that bathroom.
    Jerry
    Constantine, MI
    7,890
    Whew! I thought someone was messen' with my scotch!
    I agree with Doorlink - this room needs an upgrade, and uprighting.
    www.wrworkshop.com
    Inside the Beltway
    2,666
    geez... right side up...
    As you can see, there was a sink attached to the wall...
    Bill
    Inside the Beltway
    2,666
    So, more details...
    It was pink when we moved in. Doorlink ordered new wallpaper long ago (there's a square of it hanging up on the left). Until this weekend, all I'd done was to put in a new cabinet (you can just see part of it in the extreme left). When we moved in, there was a wall oven on the north wall of the kitchen. Once I got her new double oven cabinet made, I took out that oven, and discovered there was a 32" by 30" floor to ceiling space. So I cut through the bathroom wall to open it up, framed it out, and built an internal cabinet in place. Sliding doors on the bottom, recessed doors and shelves on top. Then other projects took over...
    So saturday we bought all the stuff, which is how she gets me going. Sunday I started going after it. As you may have heard, the university is having a visitor this week, and I'm involved with that, and Doorlink is in the choir singing at the national stadium (her mother is thrilled she gets to sing with Placido), so things are really crazy right now, but as the saying goes "there's never a good time". Anyway, the sink came out without too much trouble, but I needed to replace all the 40 year old plumbing fixtures.
    The toilet was another story. Wrestled with it a long time, finally gave up on one of the tank bolts and just brute-forced it off. Then the base. One nut came off, the other would just spin. No room to get a hack saw in there... after nearly an hour of uttering bad words, I broke out the angle grinder and fixed that bolt's wagon... The lighting was bad until those sparks started flying. After that, no problem seeing the work site...
    Then the old tile... oh, my goodness. They just poured mortar over the subfloor and then thinset the tile down. I guess cement board didn't exist back then. Doorlink suggested I just take a hammer and break up each individual piece. Yikes! After I got the first piece out, I took a big (BIG) screwdriver and whacked it with a hammer to get it under each piece, and pop it up. It took a while. At one point, I counted hammer blows for each tile... averaged about 20. Nine tiles a square foot, times 20 blows each, times 20 square feet and we're talking 3,600 hammer blows. Should have broken out the air chisel...
    It made a complete mess of the surface. And when we unwedged the threshold (using a japanese pull saw to cut off just a little of the doortrim to get that piece of old marble out), well, that part of the subfloor was even worse. I could look through it to the basement. Got that sealed up enough to accept new thinset. Then I broke out the tile saw, and a brand new diamond blade, to cut the new piece of marble Doorlink picked out for the threshold.
    That was a nightmare. I'd get a good cut, all the way to the last half inch, then the piece would break. Did that three times, even with Doorlink supporting the long end. Finally got an acceptable trim cut on one side, and went to cut it to length. It happened again... not bad, but not perfect either. Very frustrating. It will be where no one will see it, but I'll know it's there. Rats. But got down the layer of thinset, and got the durn thing fixed in place.
    Then, it was time to do something about the surface. Back to the borg for self-leveling compound. I'd never used it before, so had to do some web research. Like most things, they make it sound way more complicated than it is. Ended up mixing the entire bag, and using about 80% of it. By then it was 9:00, and I just put a baby gate across the doorway, and tried to call it a night. Of course, young James tried to storm the battlements, but luckily he was repulsed, and the floor looked pretty good this morning...
    This evening, I get to start cutting the new marble tile to fit. Not looking forward to cutting the round section around the floor pipe for the toilet, but what can you do? Gotta find a way. Also, not looking forward to intalling the pedastal sink she picked out, but I've got many problems to solve before I get to that...
    Bill
    London, Ontario
    3,383
    My my, Bill, but that was one ugly bathroom. Ugly with a capital "ugh".
    I wonder what people were thinking when they put in these salmon pink, (or coffee brown, or olive green, or lavender-purple... I've seen all of those) bathroom fixtures. Give me plain white, or "bone", any day. I'll go with the colour on the walls, that is a lot easier to change.
    oh, and thanks for rotating the pix.
    ...art
    I really like the current sink. The 1950's poodle-pink toilet really speaks to me. At the very least, try to preserve those two key features. They really carry the "look" of the bathroom.
    All kidding aside, we all must pay the price of all that blissful peace we garner from our time in the shop. Have fun with it.
    Cedar Park, TX
    320
    Sounds like you're really having a blast and just wanna make it sound like you're not having fun.
    Oh, and don't worry about snugging up real close to that toilet pipe. The John covers quite a lot of the floor around it when it is installed. Looks like it is coming along and that swatch of wallpaper Doorlink picked out is a Classy one.
    Jerry
    5,320
    Well, Bill...
    Having just recently finished a project like that, I can feel for you, buddy. Mine had a vinyl floor over luaun ply, so the floor tear-off wasn't so bad, but the fun ended when it came time to move the toilet 'just six inches to the right...' That involved taking down some of the basement ceiling, and re-doing the toilet floor flange and mating the new one to the shortened old pipe. (Fernco fittings are your friend!) then, patching the old hole in the subfloor and then putting down the new cement board and the new flooring. Also changed the sink style, and the new sink's drain didn't line up, so tear into the wall and re-do the sink drain.
    All fun, and I didn't even get a new Festool out of it!
  1. Tapatalk dialog strikes again :(
    By Toni Ciuraneta in forum Off Topic Discussion
    Last Post: 03-04-2013, 08:17 PM
  2. Doorlink is Famous!
    By Bill Lantry in forum Off Topic Discussion
    Last Post: 12-06-2010, 09:21 PM
  3. Doorlink's Birthday present
    Last Post: 10-23-2007, 09:53 PM
  4. Tonight's episode of TOH
    By Jim O'Dell in forum General Woodworking Q&A
    Last Post: 08-31-2007, 12:27 AM
  5. To Steve, from Doorlink
    Last Post: 05-31-2007, 03:31 AM
