Results 1 to 4 of 4
Thread: Wood Problems
    Wood Problems
    Got this on going project, rebuilding an antique Model T towncar
    when I needed a couple pieces of Maple. So from my stash I pulled a 4X4 and cut it on the RAS. I had seen the worm holes but didn't know what would be inside...
    I think these need some special lathe treatment rather than car body, Off to go find some more Maple.
    I agree. I've heard the only fix for a maple problem like that is to spin the little buggers out of it.
    How would you mount it? End grain as a box or on the side? Which side? Brad wanted to send you a piece of KY wood so maybe I'll send you a chunk of this wood. PM me with an address & I'll send forth a piece for turning.
    I was thinking end grain...perhaps something like a pepper mill? It's 4" x 4", which is bigger than it'd need to be. And if there are bug holes, it'd be hard to keep the pepper in it. Perhaps a thin vase? Turned into a 4" x 4" x 4" block, it could be turned sideways for a neat little box, bowl or hollow form.
    If you'd like me to give a piece a whirl, I'd be honored. PM is on its way.
  1. Power problems with the new saw
    By Drew Watson in forum New Tools
    Last Post: 07-23-2011, 05:35 PM
  2. Problems with my planer
    By Allen Grimes in forum General Woodworking Q&A
    Last Post: 02-18-2008, 07:23 PM
  3. Floor Problems!
    By Ed Nelson in forum Carpentry and Construction
    Last Post: 11-28-2007, 01:37 PM
  4. Jointer Problems
    By Gregory Hairston in forum General Woodworking Q&A
    Last Post: 12-30-2006, 04:46 PM
