Just thought that someone would be interested.
Chuck Hanger
Surface ground cast iron table with miter slots and beveled edge provides a sturdy, flat work surface
Steel extension wings increase your work area for larger work pieces
See through blade guard with splitter and anti-kickback pawls helps protect operator while giving a clear view of the material being cut
1-1/2HP maxi-torque 115V/230V motor prewired for 115V operation
Exclusive double-drive power system transfers more power to the arbor than conventional belt-drive systems
One-piece trunnion design offers increased strength and rigidity for more accurate cutting
Miter gauge with positive stops for accurate cross-cutting and mitering
Horizontally braced steel leg stand adds strength and stability to the saw
Left tilting for more controlled bevel cutting
Shrouded Blade increases dust collection efficience
Will admit that the photo was taken from the jet web site as the unit is still disasambled in my garage. Also there is not a wheel carrier for this unit. Will throw in a 80 tooth finish blade with it. Still has 3 years of warranty.
Thanks to all of those who look,
Chuck Hanger
shauck100@charter.net
937-935-1419
