Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: Fluted box with carved flower top
    Villa Park, CA
    1,407
    I'm not much of a turner, but I saw a piece with flutes in it like I did here and decided to try one myself. I carved a very simple flower on the top. I may try another one like this with a different top in a few days.
    I'll use this one to show carving students how they can use their carving skills.
    Mike
    Ancora imparo
    Mike that is beautiful, the carving adds so much to the nice turned box!
    30,008
    Not much of a turner? I know I sure can't cut nice clean beads like those. (Or at least haven't been able to so far.) I like the carving, too. Nicely done on all counts, Mike.
    Roanoke, Illinois
    212
    Thats really nice. I love the carving. What is the size?
    Charlotte, NC
    1,487
    Really nice Mike! The flower really adds to the box. Good job on the beading too!
    Catalunya
    4,632
    Good mix of techniques! Here we a prove that the sum of the parts is better than the parts themselves alone.
    I love it! Is the wood walnut?? at least it looks walnut to me.
    Best regards,
    Toni
    Jul 2007
    Des Moines, IA
    854
    Mike, very nicely done. I like the way the beads hide the way the lid fits. The carving is really nice to. My Dad did some carving too but I haven't tried any as yet.
    Oct 2007
    Harvey, Michigan
    687
    Mike - that's a nice piece! Good job on turning the box! I like the way the carving is subtle and blends into the form. It doesn't jump out at you but once you see it - it holds your attention. Very nice work!
    Steve
    Villa Park, CA
    1,407
    I mostly do furniture but I do these small things to use up the offcuts from the furniture making.
    The box above is about 4 1/2" in diameter. The carving is VERY simple - and shows how a turner actually has an advantage in adding carving to turning projects. Most of the hard work is done on the lathe. See the pictures attached. I use a bowl gouge to rough out the shape of the flower but you could use a scraper if that felt better.
    Once you have the shape, part off the top and glue it to a board with cardboard between the board and the top. The reason for doing that is you want to hold your work down while you're carving on it. [Aside comment: You can remove it by putting a chisel between the work and the board and tapping the chisel - the cardboard will split. Rub the work on a piece of sandpaper to remove the cardboard and glue or use a ROS - hold the work against the sander.] [Another aside comment: The rough flower shape is perfect for mounting in a chuck if you want to shape the underside of the top in some fashion - for example if you wanted to make the top thicker for some added decoration on the side and wanted to hollow the center of the top.]
    Take a set of dividers and step off the petals. Five is a good number but you can do more. Avoid even numbers - an odd number of petals looks better. Draw a line from each divider step to the center. The best tool to use to carve along each line is a "V" tool but you can use a regular chisel by cutting in towards the line to make a V shaped line. Now, round off the corners of the petals. I use a gouge to establish the line but you can use chisel - it's just a bit harder to get a nice round line. Sandpaper will help smooth the line. I then hollow out each petal a bit to give some more shape but you can skip that step. Finally, I cross hatch the center and put three lines on each petal for additional interest. Sand the petals smooth to get rid of the tool marks.
    While carving tools make the job easier, you can use regular woodworking tools and do a good job.
    Give some "turned flowers" a try!!
    Mike
    [PS: an added thing you can do is drill out the center of the flower and insert a different color wood for contrast, or to make a longer "handle" for removing the top. Of course, do this drilling before you part off the top.]
    [To answer the question Toni asked, the wood is walnut - offcuts from a table I made.]
    Attached Thumbnails Attached Thumbnails Flower-carving-001.jpg   Flower-carving-002.jpg   Carved-Flower-001.jpg
    Ancora imparo
    Charlotte, NC
    1,487
    Thanks for the tips. It will go into my bag of things to try!
  1. Cactus Flower
    Last Post: 08-13-2014, 10:54 AM
  2. I will Not turn into a hot-house flower...
    Last Post: 10-03-2011, 04:24 PM
  3. Building a raised flower bed
    By Chris Mul in forum Carpentry and Construction
    Last Post: 09-16-2010, 10:21 AM
  4. Spiral Fluted Vase
    By Cody Colston in forum Lathe Project Showcase
    Last Post: 10-01-2008, 03:39 PM
