Results 1 to 7 of 7
Thread: 10" Ryobi Table saw extention plan?
    St. Clair Shores, Michigan
    11
    I have a 10" Ryobi table saw which needs extention wings from the sides. It's one of those $99 Ryobis that Home Depot was selling earlier this year.
    Anyway, I'm set on an extention for outfeed; when I built my woodworking bench, I built it 1/4" lower than the surface of the table saw. The woodworking table is 33" X 72". I've discovered that I do need extention wings though to handle wider panels.
    If anyone knows where I can find any ideas, It would be much appreciated.
    Jul 2007
    DSM, IA
    5,719
    Michael, I don't remember who posted or where it was posted, maybe here? I have this photo of a setup that might work for you. I have a delta shopmaster, pretty much the same thing as your ryobi and have tried to figure out how to make something so I could still use the fence with ext. wings....so I will be watching this thread.
    PS just remembered that I almost bought another shopmaster delta TS that had a shot motor and cracked plastic for $30. My thought was to bolt the other table top to my current one for an ext. wing so I could use the fence. It was sold before I got in touch with the seller so that never happened....but could maybe work if you coud find one for your ryobi.
    My Website
    39.92*N x 86.01*W
    112
    Jeff -
    That's my shop-built table saw cabinet, for my Ryobi benctop saw. There's a thread on it hiding around here, someplace, and there was one on WoodWorks, but given the problems they're having, it might be gone.
    Here's another shot of the Beast:
    -Kevin in Indy
    "Heroic? He fell off his bloody Aeroplane!"
    Jul 2007
    DSM, IA
    5,719
    I thouhgt it was from here Kevin....Here is that thread >link< and a quick >link< to more of Kevins pics of his fence for it too.
    I forgot about the fence you made Kevin...thanks again.
    My Website
    Jan 2008
    Lived in Michigan until I retired in Mexico. Build furniture for use. If I need it I build it.
    46
    Michael, don't know how elaborate an extension you need, but I had the same problem and built this quick extension to trim plywood. Only need six pieces of scrap wood, the pics should explain all.
    Does anyone know what type of fence that he has used on this? Thanks.
    Dec 2011
    Warrington PA
    3
Name:	table saw cabinet 005.jpg
ID:	64934You might try this site for BT3's
    http://www.bt3central.com/index.php
  1. Ryobi router table switch gone bad
    Last Post: 06-27-2010, 04:54 AM
  2. picnic table plan
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 05-03-2010, 05:38 PM
  3. Coffee table plan?
    By Warren White in forum Designs, Plans and Sketches
    Last Post: 04-11-2008, 06:29 PM
  4. anyone else use the $99 ryobi table saw?
    By Mike Gager in forum New Tools
    Last Post: 03-16-2008, 06:37 AM
  5. My old ryobi table router has bit the dust
    By Jim Hager in forum General Woodworking Q&A
    Last Post: 01-13-2007, 01:01 PM
