Al killian
- Floydada, Tx
I am nearing the end of my long shop move and looking for ideas on how to make the hole in the wall to go thru a block(cinder) then go thru the waincoting(sp?). The hole in the wood is fairly easy, I just make sure I am clear of any 2x in the wall. Would it be best to get a hammer drill and make a circle of holes. Then chisel out between the holes?
This what makes the old building so hard to work on. The wall I have to go thru is almost 2' thick.
The block is 1' thick, then each side has a 2x4" wall coverd by 3/4" wainscoting. What fun!
