Results 1 to 10 of 19
Thread: scared of drawers
    Sep 2007
    Central (upstate) NY
    1,457
    scared of drawers
    I'm going to add some drawers to the reloading bench this summer. Partly to help me organize stuff and partly to learn how to use that PC dovetail jig that's been sitting on the shelf awhile now. I don't want to get into how long exactly, but it does predate Ned's shop. I've never made a drawer at all, jig or no jig.
    I'm thinking to make them out of plywood for the invisible parts (sides, bottoms, backs) and maybe some soft maple for the fronts (I have a little maple on hand). Right now, the only router I have is a PC8529 plunge, 2.25 hp that mostly lives in the table. I would like to get a fixed base router, especially for the dovetail jig, but I don't know if it is in the budget. If I can squeeze one out, how important is variable speed for a fixed base unit that is a 2nd router? Would one of those Hitachi 2.25 fixed base units do well? Or would it be easier somehow to use a PC router with the PC jig?
    Next, what should I be reading and thinking about as I contemplate drawers? I feel like the biggest newbie here as far as actually using my tools.
    Thanks!
    Apr 2008
    Butte Montana which is 1/2 way between Purgatory and Heaven
    170
    http://www.woodmagazine.com/wood/fil...layer&temp=yes
    Here is a video that saved me when I needed to learn how to make drawers. if for some reason this link doesn't work go to Woodmagazine.com
    Good luck
    Jiggs Elphison
    Apr 2008
    170
    Here's another guide for drawers....
    http://www.taunton.com/finewoodworki.../011045032.pdf
    Jiggs Elphison
    Jiggs, both of those are great links, thanks much!
    (second link requires membership)
    30,017
    I'd think a fixed-base PC 690 would work fine as a dedicated dovetail router. That's what I've used. Keep in mind this is from a guy who has only used his Rockler dovetail jig long enough to try it out on some scrap wood...I've not made any drawers, either.
    NH
    4,005
    I have a PC router that works perfect with my PC dove tail jig. I have found that the PC collars for the base don't fit just any router. I have never tried dovetailing plywood. I would think it would blow out in all the wrong places.
    Houston, Texas
    2,323
    Hi Mark,
    About being scared of your drawers. Don't be!
    If they don't fit try a different brand name. I like Fruit of the Loom but Hanes has some that are not so scary. You just have to do what it takes to get started! Good luck with those scary drawers! I believe in you!
    Shaz
    Please join me. Register now.
    Shaz
    Here is how
    Southern Louisiana
    947
    mark, just check the PC guide bushings to see which brands they adapt with. To find this out you may have to check the kit that has the multiple sizes of bushings. i think they list it on the back.
    Amazon has run some great deals on fixed base 690's recently, and most people say that router is bulletproof. i know i like mine. i've had no problem except the cracked housing caused by getting my foot wrapped around the cord and draggin it to the concrete.
    plywood will do fine with the jig as long as you provide a backer board for blow out. make sure to try it out on some test pieces.
    good luck
    chris
    13,448
    I used to have the PC D-handle base for my fixed router. It worked well for the dovetail jig.
    Odessa, Tx
    1,813
    Mark the answers above are good, but to be specific about the question you asked, ANY BRAND of router that states that it will accept the PC (or sometimes noted as "PC style") guide bushings will work fine with the PC Dovetail jig. If the small bits like the ones you will use with the dovetail jig are all you are going to use with that router, a variable speed is not necessary. With those statements in mind, I have some older routers that are fixed speed, but when I buy now, I usually buy the VS models, just to give me more flexibility should I feel the need for it.
    On a further note, there was a period a year or so ago that there were quite a few posts on different forums complaining about bearing failures on the (new, at that time) PC 690 routers, and several comments from long time users of the 690 series that indicated that they didn't feel the new ones were built as well as the older ones. Does anyone know if Porter Cable has taken care of that problem? I don't remember seeing any complaints recently, so maybe that problem has gone away, I just don't know.
    A router with a D handle OR an offset base would assist in keeping the router flat on the jig though.
    Have fun with the Jig and making drawers.
  1. Scared the heck out of me
    By Bob Gibson in forum Safety Tips
    Last Post: 07-10-2016, 05:44 PM
  2. 27 Drawers
    By Tom Hoffman in forum Flatwork Project Showcase
    Last Post: 12-23-2010, 06:07 AM
  3. Portable Chest with Drawers - How to keep drawers from opening?
    By Brent Dowell in forum Designs, Plans and Sketches
    Last Post: 05-22-2010, 06:41 PM
  4. My Big Drawers
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 07-09-2009, 01:10 AM
  5. What are you scared of
    By Robert Schaubhut in forum Designs, Plans and Sketches
    Last Post: 09-05-2007, 11:15 PM
