Results 1 to 8 of 8
Thread: BOW European
    Texas-The Greatest State
    87
    BOW European
    I tried a little different design with this pen. I could not get the CA finish on this pen perfect even tough I tried about 6 times. There is two small areas where the CA has a dull look to it. Maybe someone can help me with that. Other than that it's OK.
    What do you think about it?
    11,697
    Looks familiar.
    Often times I don't even put a finish on olive wood. Has a nice feel all by itself and takes a nice sheen with fine grit sanding. I use Micro Mesh up to the 12000 grade then do a final buff with an old hunk of wool blanket material. Other times I have put different finishes on with no problems. I have used Myland's, Deft spray laquer and others. Never have used CA on olive wood. You might try a caranuba base wax.
    Moro,IL
    22
    Travis I suspect your dull light spots are caused from heat buildup while polishing. I experienced this and solved it by using one of Russ Faifield's tips of applying a liberal coat of BLO immediately after applying the CA, do it quickly before the CA has a chance to dry. I have had much better success using this method.
    Hope this is of some help to you.
    Todays mistakes can be tomorrows gain
    87
    Quote Originally Posted by Bob Watsek View Post
    What is BLO?
    Moro,IL
    22
    BLO is boiled linseed oil.
    87
    Oh thanks! I have some and didn't even know.
    11,697
    Bob, do you have Russ' video saved on his CA/BLO method? I recently dumped mine. Vaughn is asking about this in another thread.
    Moro,IL
    22
    Frank I'm sorry I dont have the video but I can give you a link to his website that describes this technique.
    http://www.woodturner-russ.com/FSOriginal4.html
    Hope this dont get me in trouble with the Mod's.
  1. European Premium
    Last Post: 04-27-2009, 10:41 PM
  2. Any of our European members in danger?
    By Greg Cook in forum Off Topic Discussion
    Last Post: 11-08-2007, 11:11 PM
