Results 1 to 10 of 13
Thread: A couple of new things for me
    I got back on the lathe here lately. Had some rough blanks lying around that I decided to finish. I roughed them out a long time ago so they were both hard as nails. Sorry the pictures are mixed up; don't know how to rearrange them. The first is red gum eucalyptus 8.5"wide x 6.5" high. Left the natural edge, sans the bark. That was about as hollow as I could get it with standard tools. I found a neat trick for smoothing the inside though. I used a goosneck scraper with the bowl turning at very low speed (about 10 rpm) saved me a ton of time sanding. Another first was that I rubbed out the laquer finish with 4F pumice and oil. It gave it a nice semi-gloss sheen rather quickly.
    The second bowl is carob 9" wide x 4.5" high. decided to add a ring to it for kicks. The ring is Peruvian walnut. I started by cutting the bowl in half on the bandsaw using a makeshift jig to steady it. Then sanded the mating surface of each side flat using first the belt sander, then I attached a sheet of sandpaper to the cast iron tablesaw wing and rubbed the surfaces on it they they were perfectly flat. Then cut the ring to rough size out of the walnut. I glued the top and bottom to the ring separatly to minimize the slipping and sliding thing that wet glue does. Then turned it to final finish. Another first on this was using Mylands friction polish. Worked great, although I hear its not that durable As far as the design, I'm not that crazy about it, but I plan to play with the concept more in the future and come up with something more to my liking. BTW The Eucalyptus is from the same chunk that George Conklin made his recent posting from, notice the bee's wing figure; quite common in this wood. Cheers, Barry
    Attached Thumbnails Attached Thumbnails nat edge euc1.jpg   carob with ring3.jpg   nat-edge euc3.jpg   carob with ring1.jpg
    Sep 2007
    613
    Barry, outstanding work on both pieces. The carob with the added Peruvian ring is special, even you did it as a trick. I like your story about using a scraper with a very low speed, yes I believe this saved you a lot of sanding time, have to try that.
    Keep up your good work
    Ad
    Looking good!
    I'm quite curious about your 10 rpm scraper method, I'm not really getting how that would work
    Grand Rapids, MI
    383
    Hmm
    I am assuming you mean a hand scraper, like what instrument makers use? If so, I have been wondering about this type of thing recently. In my mind it seemed to be a good way to smooth the inside of bowls, but hadn't heard about anyone using it before.
    Hutch
    Hi Barry,
    Your work looks great as usual. That euc looks scary thin. Nice job.
    Thanks for sharing.
    George
    S E Washington State
    3,777
    Very nice work
    Goodland, Kansas
    4,834
    Barry great looking pieces. I agree with Stu. Wondering how 10 rpm works with a scraper? I would like to see a pic's of your goose neck scraper.
    Bernie W.
    Guess I should be more specific. I was refering to a gooseneck 'card' scraper. A small handheld piece of spring steel with varying radi around it. They are used most often for smoothing contours on flatwork. Rockler, and about everyone else, sells them.
    30,002
    Cool stuff, Barry. The eucalyptus looks a lot like the stuff I got from my office. I like the striped piece, too.
    Red Deer, Alberta, Canada
    618
    Nice pieces, Barry! I like them both a lot but I think the carob/walnut would have to get my vote as favorite of the two.
    Thanks for sharing.
    Why has common sense
    become so uncommon?
    My Woodwork Site
  1. Couple of new things
    Last Post: 02-13-2013, 12:54 AM
  2. Couple of new things
    Last Post: 01-16-2013, 06:43 PM
  3. Couple of Things
    By Brent Dowell in forum General Woodturning Q&A
    Last Post: 01-10-2010, 03:30 AM
  4. A couple of new things...
    By Bartee Lamar in forum General Woodworking Q&A
    Last Post: 08-26-2007, 01:17 PM
  5. Tried a couple new things!
    By Ed Nelson in forum Lathe Project Showcase
    Last Post: 07-14-2007, 09:21 PM
